Author Topic: Interior or dome light issue  (Read 1684 times)
Offline Stevepd
  • -Given: 49
« on: December 19, 2014, 08:20:28 am »
Mine hasn't worked since I bought the car. Yesterday I had the time so had a look at others post on how too. Removing the panels to reveal the rocker switch which I took out and gave it a clean. The info said to bend the legs apart a bit as they can go together, so did that and refitted which instantly blew the fuse. I've removed the rocker switch again and replaced the blown 7.5amp fuse. Can anybody offer any further advice on how to set this up.
The light do work if you push the rocker switch quite hard but release your finger and they go off. Everything else works as advertised.
Standard 5 Door Shadow blue.
Offline callis
Re: Interior or dome light issue
« Reply #1 on: December 23, 2014, 10:52:49 am »
Hi
Guys i have the same kinda issue with my rocker switch. However my legs have lost their spring.
So can anyone give me the part number and price so i can get a new one ordered. The VW garage is a distance from me and they are not very good on the phone.
so its the interior rocket switch.
cheers
05 GTI 5 Door, sunroof, met paint, 18" monza, Leather Anthacite, front centre armrest, xenon headlights, Lux pack 2, Sensors, Winter Pack.
Offline doylebros
  • -Receive: 310
« Reply #2 on: December 23, 2014, 01:02:34 pm »
« Last Edit: December 23, 2014, 01:05:14 pm by doylebros »
Offline callis
« Reply #3 on: December 23, 2014, 03:00:52 pm »
hmmm, now thats a bummer. Guess i will have a play and see if i can fix it myself.
Offline andybon
« Reply #4 on: May 05, 2015, 05:38:01 pm »
Mine has just done the same, stopped working so had a look and it looked really grimy inside, cleaned it and when it came to putting it back together there was no tension on the switch, now the fuse has popped!
How hard can it be?
