Author Topic: MK5 GTI brake upgrade options?  (Read 25477 times)
Offline LowProfile
« on: December 24, 2014, 06:21:39 pm »
Not sure weather its just my car or all GTI's but the brakes dont seem the greatest if im honest!
Is there any OEM upgrades ie R32 that is a worthy upgrade? also ive got the 18" monza's so is there any issues with clearance?
Pictures would be great!
Cheers :happy2:
Offline flashp
  • -Receive: 65
Re: MK5 GTI brake upgrade options?
« Reply #1 on: December 24, 2014, 06:26:20 pm »
R32 / S3 is a great improvement on road but can run out of headroom on track depending on you and your available power.
« Last Edit: December 28, 2014, 08:08:52 am by flashp »
Gone but not forgotten :-)
dansmith180
« Reply #2 on: December 24, 2014, 06:39:50 pm »
Yeh the standard brakes are a bit pants really, R32 setup is a big improvement but as above can fade when really pushed, also they can fit behind almost any wheel inc a few 17" wheels.
Offline kr15h_ED30
« Reply #3 on: December 24, 2014, 06:40:11 pm »
the standard GTI set up isnt the greatest. R32 set up is good for stage 1. If you want more power look at the TTRS brakes from Alex at aks tuning.
Offline LowProfile
« Reply #4 on: December 24, 2014, 07:08:44 pm »
Cheers guys for the replies.. theres a couple of sets of S3 front brake set ups for around £500 i think.. sounds about right? :driver:
dansmith180
« Reply #5 on: December 24, 2014, 07:35:08 pm »
Yeh depending on condition and life left in pads/ discs anything between £350 and £500 is pretty reasonable.
For £500 I would expect nearly new pads/ discs and calipers in very good condition.
Offline th3_f15t
  • -Receive: 183
« Reply #6 on: December 24, 2014, 09:23:06 pm »
With regards to the R32 upgrade, you may want to consider the following;
Mk5 Golf R32 - Blue calipers
Audi S3/Mk6 R - Black calipers
Seat Leon Cupra - Red calipers
Also, if you want that bit extra performance, look at getting some 340mm TTS brake discs, a few kilograms lighter than the OEM 345mm discs. Some decent pads will also be worth spending the extra on too.
Offline LowProfile
« Reply #7 on: December 26, 2014, 04:04:36 pm »
sorry for late reply.. il look into that mate cheers! guess im on the lookout for K1 brakes then seeing as the calipers are red!
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #8 on: December 26, 2014, 04:05:43 pm »
I'm going a group buy in jan on HEL brake lines. they make a massive difference
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline Fozzy
« Reply #9 on: December 26, 2014, 04:36:29 pm »
Are all these brake setups all the same specs 345mm? I agree the brakes are naff on my ed30 and again prefer red calipers but takes nothing to spray then up properly?
dansmith180
« Reply #10 on: December 26, 2014, 04:50:03 pm »
The S3/ R32 and Cupra 345mm setups are exactly the same except the colour.
Offline Fozzy
« Reply #11 on: December 26, 2014, 05:27:52 pm »
Cheers Dan I thought this is the case? After a set in the new year...seem to see S3/r32 set ups and not cupra's or am I man looking :confused:
« Last Edit: December 26, 2014, 05:36:31 pm by Fozzy »
dansmith180
« Reply #12 on: December 26, 2014, 05:47:32 pm »
There aren't very many Cupra's so that's probably why, I noticed the same when I was looking
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #13 on: December 27, 2014, 08:51:50 am »
S3 & Golf R / Scirocco R 345mm calipers have little wings at either end, makes them look a bit bigger  :happy2:
The R32 & a Cupra calipers don't have this. Makes no difference to the performance of the caliper though
Offline dan_the_v8man
« Reply #14 on: December 28, 2014, 09:09:58 pm »
Also if you're after a bargain the Mk2 TT V6 brakes tend to go cheaper than the others but are the same 345mm setup, a set of pagid discs from eurocar parts won't cost much more than £100 so would highly reccomend new pads and discs, using used can be a problem unless you get them setup exactly as they came off the car, I.e. which pads and discs came off which side
