Author Topic: 2l tdi mk5 project.  (Read 13248 times)
Offline ryder2012
Re: 2l tdi mk5 project.
« Reply #15 on: December 30, 2014, 11:27:32 pm »
brakes clutch and flywheel are on the list.
looking at the R32 brakes or better.
im also looking into hydraulic handbrake, found a company that is manufacturing them but not available just yet.
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #16 on: December 31, 2014, 12:05:11 am »
Don't go for the R32 brakes if you're worried with weight. I fit the front brakes and they're heavy.  :wink:
For my needs their stopping power is more than enough, though. :smiley:
Happy modding! :drinking:
Offline ryder2012
« Reply #17 on: December 31, 2014, 12:09:12 am »
thanks for heads up, can you recommend any good lighter brakes?
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #18 on: December 31, 2014, 12:22:36 am »
Depends on your budget and how handy or how long you're willing to wait to get all the parts needed to assemble a good BBK.
You have good BBK in the Mod Catalogue: http://www.mk5golfgti.co.uk/forum/index.php?page=mods&cat=20
I wouldn't mind having one of these if I had a better setup or engine:
http://www.mk5golfgti.co.uk/forum/index.php?page=mods&mod=20
http://www.mk5golfgti.co.uk/forum/index.php?page=mods&mod=54
Offline ryder2012
« Reply #19 on: December 31, 2014, 12:26:20 am »
wow good few grand there then. quick search for brembo from a porche is 2/3 grand.
will be worth it though.
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #20 on: December 31, 2014, 12:31:40 am »
Getting the whole kit can be (much) more expensive but it'll save you a lot of trouble on getting the needed parts all together.
dansmith180
« Reply #21 on: December 31, 2014, 01:03:58 am »
I switched my R32 setup to the TTRS 4pots for just over £1000, I have 340mm TTS discs so theyre as light as you can get without spending a lot on 2 piece discs.
This setup is about 4kg lighter per corner than the R32's.
Offline ryder2012
« Reply #22 on: December 31, 2014, 01:05:40 am »
sweet will look into those as well.
thanks.
Offline xjay1337
  • -Receive: 377
« Reply #23 on: December 31, 2014, 09:43:53 am »
TTRS/DB9 brakes, hel braided lines
Slotted rotors
Pagid RS4-2 pads
Braided lines
new fluid all round
The kit without fluid or fitting is £1200. best bang for your buck and very cheap really. very very light.
need solid or uprated wishbone bushes too...super pro ball joints, subframe spacer kit
Offline ryder2012
« Reply #24 on: January 02, 2015, 09:39:36 pm »
Slotted rotors
Pagid RS4-2 pads
Braided lines
new fluid all round
is that the kit from the mods section? if so how do you go about getting one as i'll get the brakes sorted first up.
Offline xjay1337
  • -Receive: 377
« Reply #25 on: January 03, 2015, 07:26:40 pm »
Alex at AKS.
01234 82 23 24.
Online dom069
« Reply #26 on: January 03, 2015, 08:00:08 pm »
So you're worrying about the weight of intakes, yet add a load of audio gear in the boot? Don't get me wrong, I'm not wanting to come across is being critical, but that doesn't make any sense to me.
BC Racing Coilovers : R32 Rear Bumper : Milltek Cat Back : R32 Rear Lights : S3 Brakes : Colour Coded Side Skirts : US Grill : 18" BBS CH : De-Wipered : Bluefin Remap : Pipercross Filter : S3 Short Shifter : Powerflex Wishbone Bushes : MK6 Steering Wheel : RCD510
Offline ryder2012
« Reply #27 on: January 03, 2015, 08:04:50 pm »
highlight points.
remove weight
additional weight can be added back in through other accessories.
Offline Jcarroll
« Reply #28 on: January 03, 2015, 10:57:46 pm »
So confused by this thread but good luck, always happy to watch a build - especially when the aim is the beat a VXR!!
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #29 on: January 04, 2015, 10:38:44 am »
How much do intakes weigh? Standard and aftermarket?
