Author Topic: Retro fitting  (Read 2279 times)
Offline chipmunk82
Retro fitting
« on: January 11, 2015, 07:51:42 pm »
Hi, have a few questions and couldn't find anything specific so thought I would ask here!
I have a manual Edition 30 with a few extras, mfsw, highline dis, armrest with ipod dock (standard stereo I think) folding mirrors, and an aftermarket 3200 LS parrot bluetooth.
1)Would ideally like cruise control (and maybe xenons at somepoint but for now the osram nightbreakers are fine!)
Is there a specific one I should get and is it activated already after fitting?
2)Is there a way of finding out the factory spec of mine from chassis number? I read there should be codes in the service book but mine has a duplicate book from VW
3)I'm assuming that any retrofits are classed as modifications and should be declared on a like for like policy?
Many thanks for any info
Mike
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: Retro fitting
« Reply #1 on: January 11, 2015, 08:00:02 pm »
1) cruise control will need coding once fitted
2) If you lift the carpet in the boot there's sticker with the same codes as the service book
3) yes all mods need declaring, including retrofits   :happy2:
Offline chipmunk82
Re: Retro fitting
« Reply #2 on: January 11, 2015, 08:07:21 pm »
ok thanks :) will have a look under the carpet, what am I looking for? I know the paint code and engine codes are there.
Is it a generic stalk I need to buy or are there different ones for mfsw control modules?
Offline Rossimac
  • -Given: 78
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,90767.0.html
Re: Retro fitting
« Reply #3 on: January 11, 2015, 08:21:25 pm »
There are 2 models, this is the newer model 'G':
1K0 953 513 G
1K0 054 690 A
Both do the exact same thing, though - just a design change.
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: Retro fitting
« Reply #4 on: January 11, 2015, 08:28:09 pm »
On the same sticker below the engine and paint codes are 3 number/ letter codes, that's your factory options, there's a code convertor somewhere online, I'll try dig it out for you  :happy2:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: Retro fitting
« Reply #5 on: January 11, 2015, 08:29:54 pm »
Offline chipmunk82
Re: Retro fitting
« Reply #6 on: January 11, 2015, 09:21:34 pm »
Ok found the sticker and typed the codes in, does the armrest not come up or could it have been retrofitted? I have folding mirrors and highline DIS too
PRCode: 0AE = Front stabilizer
PRCode: 0BF = Rear stabilizer
PRCode: 0GG = Emission standard EU4
PRCode: 0Y1 = Standard climatic zones
PRCode: 0YC = Weight range 3 installation control only no requirement forecast
PRCode: 1AT = Electronic stabilization program (ESP)
PRCode: 1G9 = Space-saving spare wheel for temporary use radial tire (5-hole)
PRCode: 1JE = Rear sports shock absorption
PRCode: 1K1 = Mechanical clutch actuation
PRCode: 1KY = Disc brakes rear
PRCode: 1LL = Disc brakes front
PRCode: 1NL = Covers for alloy wheels
PRCode: 2FN = Leather trimmed multi-function steering wheel with decorative aluminum inserts
PRCode: 2G7 = Filler neck module 1 with insert
PRCode: 2JG = Body-colored bumpers
PRCode: 2UC = Sports version
PRCode: 3S0 = Without roof rails/roof load rack
PRCode: 3U3 = Luggage compartment cover with luggage net
PRCode: 3Y2 = electrically operated roll-up sun screenfor rear window
PRCode: 3YR = Door pockets with insert mats
PRCode: 4K3 = Radio remote controlled central locking operated from inside and safe securing
PRCode: 4R4 = Power windows with comfort operation andcircuit breaker
PRCode: 4UF = Driver's and front passenger air bag with front passenger air bag deactivation
PRCode: 4X3 = Side air bag front with curtain air bag
PRCode: 5MD = Decorative aluminum inserts
PRCode: 5RV = Right exterior mirror: aspherical
PRCode: 5SJ = Left exterior mirror: convex
PRCode: 8AG = Radio with CD/MP3
PRCode: 8GU = Alternator 140 A
PRCode: 8RM = 8 speakers (passive)
PRCode: 8ZN = Antenna
PRCode: B0N = Component parts set complying with vehicle type for Great Britain various parts
PRCode: C1B = Alloy wheels 7.5J x 18
PRCode: D80 = 4-cyl. gasoline engine 2.0 l/169 kW 16V turbo FSI homogeneous Base engine is TA2
PRCode: E2M = Edition
PRCode: G08 = Front shock absorption
PRCode: G0K = 6-speed manual transmission
PRCode: H7D = Tires 225/40 R18 92Y xl
PRCode: J0L = Battery 340 A (70 Ah)
PRCode: L98 = Suspension range 98 installation control only no requirement forecast
PRCode: N2Z = Seat covering for special editions
PRCode: QG1 = Service interval prolongation
PRCode: TA2 = 4-cylinder gasoline engine 2.0 L unit 06F.D
« Last Edit: January 12, 2015, 03:18:06 pm by chipmunk82 »
Offline th3_f15t
  • -Receive: 183
Re: Retro fitting
« Reply #7 on: January 11, 2015, 09:41:22 pm »
Be careful posting pictures that show your chassis number mate, that's something you REALLY want to keep private...
Offline chipmunk82
Re: Retro fitting
« Reply #8 on: January 11, 2015, 09:45:03 pm »
My chassis number shouldn't be showing? Are there other codes on there
