Author Topic: Help with Vw dealers for pcv  (Read 2180 times)
Offline dazjones757
« on: January 12, 2015, 02:55:49 pm »
Hi everyone could do with some help, contacted vw about getting the revised pcv for my mk5 gti, it's 56 plate but unsure which revised version is for my car so thought vw would know,  sent them details etc but the reply I got was -
" Sorry , were is the pcv valve fitted you require , when you say PCV we are presuming you mean pressure control valve  but unfortunately there are various pressure valves on your vehicle.
If you could tell me where the part is you require then I can get back to you with a part number, price and availability. I can also send you pictures to confirm that the part is correct."
Slightly confused with what I should be telling them as to be honest I don't really know alot about this myself as not long been owner of my first mk5 gti and was just going to replace this pcv part with the revised one as just going by what I read it's a weak point an prone to failing when tuning the car etc.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: Help with Vw dealers for pcv
« Reply #1 on: January 12, 2015, 03:26:56 pm »
Offline dazjones757
« Reply #2 on: January 12, 2015, 04:15:46 pm »
Cheers mate,  so that's definitely the revised version for my 56 plate
Offline dazjones757
« Reply #3 on: January 12, 2015, 07:19:40 pm »
Vw are telling me the part number ending in R is latest version and not L like it says on that link so still unsure which I need?
Offline andyR43
« Reply #4 on: January 12, 2015, 07:53:19 pm »
 The latest version front pcv is 06F129101R.
That link is from 2010.  :wink:
Keeping it original..............or not!!
Offline NathED30
« Reply #5 on: January 13, 2015, 11:54:56 pm »
^^ yep rev R is latest :happy2:
Reflex Silver Edition 30 #0063
  • -Receive: 453
« Reply #6 on: January 14, 2015, 12:02:35 am »
Do you know what version you have installed at present?
This is important as the earlier (front) pcv didn't come with a check valve in the rear pcv tube. The latest version needs to have this check valve to operate correctly.
Offline raven8472
« Reply #7 on: January 14, 2015, 08:49:31 am »
Have the part numbers for the gasket and tubing that people also replace the same or have they been revised as well. I got my DV changed and this is next on the list as a preventative measure.
