Author Topic: No boost...help  (Read 2881 times)
Offline poweller
No boost...help
« on: January 15, 2015, 10:36:04 pm »
Hi all,
Had no boost for several days now...changed DV, tested pcv...had a loom for some leaks no such luck. When i go to go in to the rev range for the turbo i hear a slight sound coming from the engine bay similar to injectors sending fuel but nothing else.
No engine management light etc...
Offline poweller
Re: No boost...help
« Reply #1 on: January 16, 2015, 04:11:45 pm »
Bump...shagged turbo?
Offline poweller
Re: No boost...help
« Reply #2 on: January 17, 2015, 10:41:32 am »
Had a vagcom read yesterday and the only faults i got was a P1531 - camshaft timing adjustment open circuit.
And 00003 control module malfunction
Would these cause a turbo cut off?
Offline th3_f15t
  • -Receive: 183
Re: No boost...help
« Reply #3 on: January 17, 2015, 02:08:33 pm »
Quite possible, yes. If the ECU can't work out what the camshaft is doing it'll go into limp mode for safety.
Offline poweller
Re: No boost...help
« Reply #4 on: January 17, 2015, 07:39:43 pm »
But i dont have an engine management light...if it was in limp mode surely it wpuld come up
Offline poweller
Re: No boost...help
« Reply #5 on: January 18, 2015, 04:31:45 pm »
Okay...so i have sorted the error and still no turbo :/
Offline poweller
Re: No boost...help
« Reply #6 on: January 18, 2015, 06:57:49 pm »
Brief but this is the noise revving at idle...
Offline wayneitb
  • My Ride: MK5 GTI
Re: No boost...help
« Reply #7 on: January 18, 2015, 08:55:21 pm »
I would look at the N75 Valve if you have boost problems, mine went on my 1.8T and it did not show any errors at all, but they are a pig to get to on a K03 turbo.
Offline poweller
Re: No boost...help
« Reply #8 on: January 20, 2015, 03:12:41 pm »
Any more ideas guys?? Before i f*cking dump the car
Offline th3_f15t
  • -Receive: 183
Re: No boost...help
« Reply #9 on: January 20, 2015, 05:19:29 pm »
Where about are you based mate? Anywhere near a good tuning company (AKS, AMD, R-Tech ect.)? Might be worth getting a proper mechanic who tunes these engines to have a look for you. Don't loose hope (as hard as it is when things are f**king up for you).
Offline poweller
Re: No boost...help
« Reply #10 on: January 21, 2015, 06:53:29 pm »
Tryna get it sorted without visiting anyone tbh...
This is pic of the turbine...seems good and the wastegate is closed so means its not bypassing...
Offline poweller
Re: No boost...help
« Reply #11 on: January 21, 2015, 06:54:21 pm »
