Author Topic: interior questions  (Read 2455 times)
Offline golfgti10
interior questions
« on: February 01, 2015, 04:24:13 pm »
If I remove the bonnet handle will I lose the cable?
also where on the internet can I buy two new airbag emblems that are on the b pillar and two new protective covers which hide the screw on the rear door cards
Offline th3_f15t
  • -Receive: 183
Re: interior questions
« Reply #1 on: February 01, 2015, 04:40:06 pm »
Not sure about the bonnet handle question. As for the airbag emblems, take the part numbers into VW and buy some, only a few quid. Same for the screw covers.
Offline golfgti10
« Reply #2 on: February 01, 2015, 04:42:59 pm »
I was hoping to do it all over the internet if anyone can help, also any ideas if there is a knack to putting the b pillar trim back on
Offline th3_f15t
  • -Receive: 183
« Reply #3 on: February 01, 2015, 05:43:15 pm »
The B pillar trim is a nightmare, took me about 30 minutes a side to get it all back in place without breaking anything. Just make sure all the clips are in the right place and the seat belt adjuster lines up, then just use a fair amount of force and clip it into place. It's not easy at all, worst part of the whole interior swap for me!
Offline doylebros
  • -Receive: 310
« Reply #4 on: February 01, 2015, 05:45:04 pm »
No you won't lose the bonnet cable.
Look here at airbag emblems for the part number which will help your search :happy2:
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1728&ein=2007&f=474&hauptgr=1234567890&hg=8&grf=086765420&bf=86765&hgug=867&ug=67&parent_id=2355764
Offline golfgti10
« Reply #5 on: February 01, 2015, 09:48:31 pm »
was just reading another thread and if you disconnect the airbag switch from the seats without disconnecting the battery the airbags will go off this true ???
Offline doylebros
  • -Receive: 310
« Reply #6 on: February 01, 2015, 09:53:11 pm »
Best practice when dealing with Airbags is disconnect the battery and let it stand for a short period (5minutes) then disconnect the item.
If you wish to do it a different way then at your own risk but you will get a warning light which will need cancelled! :happy2:
Offline golfgti10
« Reply #7 on: February 01, 2015, 10:18:39 pm »
But the actually air bag doesn't go off
Offline doylebros
  • -Receive: 310
« Reply #8 on: February 01, 2015, 10:23:38 pm »
Never did for me but I was't doing it as a test to see if it would!
Offline TAPPY
  • -Receive: 56
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,103290.0.html
« Reply #9 on: February 02, 2015, 06:14:01 pm »
It's not advisable to play with airbags with the battery connected. Basically if you unplug it with the battery connected they won't go off BUT there's also a possibility of static electricity form your body on the plug setting them off.
