Author Topic: How much for DV change?  (Read 6551 times)
Offline Matthewsimone
  • -Receive: 39
Re: How much for DV change?
« Reply #15 on: March 10, 2015, 08:31:25 pm »
Seriously mate its a 20 minute job even on normal k03 Gti and that includes jacking the car up etc
Where abouts are you il do if for a beer token  :happy2:
Checked mine few weeks ago just to make sure still in one piece etc and must have took me 15 minutes
Im located in Flintshire
Im in Leicester  :signLOL:
 :laugh:
  • -Receive: 39
« Reply #16 on: March 10, 2015, 08:33:35 pm »
If you have the right tools do it yourself , its simple and takes 30mins
The advice above is on the money - the job is simple but remember one bolt is difficult to reach and requires certain tools so be warned!
This is the tool I found made the job easy http://www.ebay.co.uk/itm/Laser-3981-Ratchet-Swivel-Head-1-4-Drive-/360643747143?pt=LH_DefaultDomain_3&hash=item53f80add47
I used a standard 1/4 drive ratchet with short extension bar and bit holder with 5mm allen key bit oh and a small flat blade screwdriver to unclip electrical plug
No special tools required
Offline doylebros
  • -Receive: 310
« Reply #17 on: March 10, 2015, 08:37:57 pm »
Seems others have had issues like me http://www.mk5golfgti.co.uk/forum/index.php/topic,87156.msg889297/topicseen.html#msg889297
  • -Receive: 39
« Reply #18 on: March 10, 2015, 08:43:08 pm »
As i said in that thread mate
The Dv on a Gti is a doddle compared to heater matrix hoses on a mk1 focus Rs  :laugh:
Honestly don't see what the fuss is about i found it a easy simple job!
Might start charging £25 to change them and do 3 an hour  :jumpmove:
Offline TaylorGTi
« Reply #19 on: March 11, 2015, 02:20:39 pm »
This was my first job I did on a car ... After fitting a cat back. This was easier haha! It's easy honest just take time and follow guide can't really go wrong and will save yourself £££. Since checking the dv iv changed the hpfp so it gives you confidence  :happy2:
R-tech Stage 2+ Pirelli Gti
Offline xjay1337
  • -Receive: 377
« Reply #20 on: March 11, 2015, 02:29:57 pm »
TbH - everyone saying it's a 20 minute job, it's not
It's probably an hour for a home job, it's easy but can be fiddly
You need to take arch liner out really unless it's on a ramp. Wheel off helps a lot.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #21 on: March 11, 2015, 03:09:19 pm »
I did mine with no other info and made the how to after. Go for it! It's not that daunting and is well worth keeping your £60
http://www.mk5golfgti.co.uk/forum/index.php/topic,87824.msg893078.html#msg893078
Offline v4rley
  • -Receive: 104
« Reply #22 on: March 11, 2015, 03:26:04 pm »
I have changed mine once with the wheel and arch liner off. I can now do it with just jacking the car up at the front and no need to remove anything to access the dv and just used a 1/4 socket. It really is a straight forward job and easily achievable in 20mins
Offline Markweir12
« Reply #23 on: March 11, 2015, 03:30:16 pm »
Tbh .. I'm a dreadful mechanic and I did it in about 30 mins on deck.
Wheel and arch liner still on :)
  • -Receive: 39
« Reply #24 on: March 11, 2015, 04:34:55 pm »
Disagree mate
Sorry but its a low skill level 15 minute job
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #25 on: March 12, 2015, 09:18:10 am »
Disagree mate
I'll second that but ONLY if you have the right tools before you start. The first time I didn't have spanners and drivers short enough to reach between the chassis and the dv so it took an hour. Second time maybe 15minutes knowing what tools I needed.
Offline xjay1337
  • -Receive: 377
« Reply #26 on: March 12, 2015, 09:50:16 am »
I'm not a mechanic but I'm no idiot, can change gearboxes/clutches etc.
It took me 45 minutes, wheel off, jack car up a bit, arch liner off etc. On a ramp like I said it's about 10 minutes and a piece of pie - angle is much better to work at.
I have big hands, maybe makes it harder.  :signLOL: :signLOL:
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #27 on: March 12, 2015, 10:11:58 am »
It depends how you go about it (whether on the deck, or wheel and arch liner off), level of skill, tools available (that one bolt is a PITA with the wheelarch cover on, but is do-able)
Either way it's an easy DIY - 3 bolts and an electrical connector
