Author Topic: DV, PVC and CAM Follower  (Read 6572 times)
Offline cooljimy84
    • Personal
Re: DV, PVC and CAM Follower
« Reply #15 on: March 27, 2015, 04:39:56 pm »
if you can fix a bike, you can fix a car, and if you can fix a car, you can fix a nuclear-grade submarine.
THIS !!
Tho don't try a fix a radar system by just sticking a soldering iron and solder on the board in a huge blob...
There is no replacement for displacement....
But a turbo does help....
Offline Pesky jones
« Reply #16 on: March 29, 2015, 09:44:38 pm »
Where do people recommend I get these parts from?
Offline PT82
  • -Given: 19
« Reply #17 on: March 29, 2015, 10:11:05 pm »
Just get them from VW
Here is the part number for the PCV gasket, you may want to change it also:
06F 103 483 E
Offline Pesky jones
« Reply #18 on: March 29, 2015, 10:32:15 pm »
Ok will do. Why do you recommend the gasket as well as the pcv?
My plan is to buy all the parts, then potentially replace the pvc(and possibly the gasket )and the cam follower myself (if it's not too challenging) , and then take it to a mechanic to fit the DV
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #19 on: March 30, 2015, 09:03:39 am »
I would have said to start with doing the DV yourself. I did a how to - http://www.mk5golfgti.co.uk/forum/index.php/topic,87824.msg893078.html#msg893078
The gasket is just a rubber seal, it will perish over time. If you're ever replacing any part on a car then you always replace the associated gasket along with it, just good practice.
Offline Pesky jones
« Reply #20 on: March 30, 2015, 09:17:55 am »
Hm, I don't have axle stands...It is very tempting though. You recommend REV G? I see you had some problems with yours after installing it?
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #21 on: March 30, 2015, 11:05:48 am »
Axle stands are the cheapest things you can buy. Although I wouldn't like to admit it, before I got a set I used 4 bales of fire briquettes on the last car when I was doing the CV and they held strong. I do not recommend this! Get axle stands from the likes of micksgarage or a UK equivalent for around £15 because you're going to need them in the future.
I've used rev G and rev D. End of the day either will do the job. It's argued that rev G gives a better seal and therefore better performance but it would be miniscule and nothing worth noting.
G is also cheaper than D.
Get a G and check back on it in a year and look for splits.
I would also check that your current one is not split before you go changing it.
Offline Pesky jones
« Reply #22 on: March 30, 2015, 11:27:32 am »
To be fair, I don't think I can hear a whistle and it seems powerful. With the scanner that I've ordered, will I be able to see if there is a loss of power?
Offline cooljimy84
    • Personal
« Reply #23 on: March 30, 2015, 12:24:07 pm »
a non vagcom will only show "errors" not "warnings" so it will check for major faults and prob won't read the VW under boost soft errors... :(
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #24 on: March 30, 2015, 12:33:41 pm »
Putting it this way, I bought my GTI coming from a polo and never realised my dv was split because it was a powerful car.
Chances are if you have no proof of it being changed it is split.
Take it off anyway and check it. Do it early in the morning so you can leave the car jacked up and pick up a part from VW parts in a different car if it does need changing.
Offline Pesky jones
« Reply #25 on: March 30, 2015, 12:39:47 pm »
Ok will do, cheers!
