Author Topic: Plate behind rear disc rattling?  (Read 1092 times)
Offline Stevepd
  • -Given: 49
« on: March 28, 2015, 04:57:02 pm »
I heard a clonk over normal roads and have quickly found its the OSR plate that's behind the disc. Is it common and easy to fix?. Can it easily be moved as something is holding it on!.
Steve.
« Last Edit: March 29, 2015, 01:03:47 pm by Stevepd »
Standard 5 Door Shadow blue.
Offline jaffa
  • -Receive: 44
Re: Plate behind rear disc rattling?
« Reply #1 on: March 29, 2015, 12:06:22 am »
Pretty common that they rust around the mounting holes
You can do a temporary repair by using washers and sandwiching the dust shield
Or you can replace them for around £30 for the two I think it is.
I removed mine as they rusted through and started rubbing against the disk.
Either way you have to remove the caliper and the disk to gain access to the screws holding it in place
Offline th3_f15t
  • -Receive: 183
« Reply #2 on: March 29, 2015, 10:56:45 am »
Mines doing the same thing but removing them when I upgrade to R32 rear brakes.
