Author Topic: Candy White Golf GTI Ed. 30 - 8th track day at Estoril  (Read 372971 times)
Offline JaseGti
    • Remoteclothing
Re: Candy White Golf GTI Ed. 30
« Reply #15 on: April 10, 2015, 09:10:48 pm »
Absolutely stunning
CW is the way forwards
Remoteclothing.com
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #16 on: April 11, 2015, 05:11:20 am »
Updated the list of modifications planned. Everything is ordered apart from the brakes and remap. Now I'll just have to wait to get all of them to then schedule with my mechanic. :popcornsoda:
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #17 on: April 13, 2015, 02:55:04 pm »
Forgot to order the CTS Turbo turbo outlet pipe but while going through the Mods Catalogue saw it and was still able to get it added to the original order.
So much stuff to upgrade... Geezz! :scared: :laugh:
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #18 on: April 20, 2015, 03:05:44 am »
Definitely talking about engine upgrades with my friends is dangerous for my wallet... :laugh:
So I postponed the front brakes upgrade and ordered a Forge Motorsport oil catch tank system for vehicles with charcoal filter (FMMK5CTC).
Decided to get the Brembo Z8 with 350 mm GL450 discs when I have funds available for them.
In the meantime more bits have arrived. There are also more that I have to pick up from shipping companies or from car part stores.
At home:
  • H&R Sport springs
  • H&R front and rear sway bars
  • Darkside Developments S3 uprated IC
  • Cherry red hazard switch
  • Mk6 brushed metal fuel door switch
  • Mk6 rear view camera
  • Mk6 OPS parking sensors front and rear
  • Bluetooth kit upgrade (7P6035730J)
  • Turbo muffler delete for K04 -> to be returned as the CTS Turbo outlet pipe does the same
Searched online about new firmwares for the RNS-510 and updated successfully my old version A to a modified 5238 with secret menu and VIM activated. :smiley:
Followed the instructions of this trusted site: http://gpsunderground.com/forum/volkswagen-seat-skoda/34434-vw-rns-510-skoda-columbus-i-firmware-guide-downloads.html
The update went well in the 1st attempt. Burned the CD image to a Verbatim CD-R at 16x. The update erased my radio list, the maps, my favourite locations and my personalized POI file. So as I wanted to go for a drive I took the opportunity to save the maps without spending more battery power. Really enjoyed the almost 40 miles of the drive. The engine and the gearbox are great as standard. :grin: Made an average consumption of 28 MPG. It's what I get on my daily driving as well. :smiley:
That's it for now.
Offline teo_parvu
  • -Given: 30
  • -Receive: 57
« Reply #19 on: April 20, 2015, 06:40:49 am »
Best version of the best GTI ever made, MK5.
This will become a monster!  :happy2:
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #20 on: April 26, 2015, 03:32:04 am »
The list of parts at home is now bigger than the list of ordered parts. I need to start fitting some of them myself. :smiley:
At home:
  • OEM front and rear rubber mats
  • Koni Sport shocks
  • SuperPro ALK with "Supaloy" brackets
  • H&R Sport springs
  • Audi TT front upper strut mounts
  • Volkswagen Passat B6 front upper strut bearings
  • Mk5 Golf R32 front bumpstops
  • Front rear trailing arm bushings
  • Rear control arm lower bushings
  • Mk5 Golf R32 rear bumpstops
  • Rear upper shock mounts
  • ITG Profilter panel filter (WB586)
  • Exhaust manifold heat shield
  • Darkside Developments S3 uprated IC with alloy end tanks and silicone boost hoses
  • NGK Iridium BKR7EIX spark plugs
  • R8 red ignition coil pack set
  • RS4 fuel pressure regulator valve
  • Full LED wing mirror puddle lights (6000K)
  • Complete interior LED set
  • Rear footwell lighting
  • PolarFis Advanced (PF03)
  • RNS-510 P version
  • DSG paddles extensions
Ordered:
  • Mk6 climatronic and Jetta mk6 trim
  • LED reverse light (6000K)
  • LED brake and parking lights
  • Door warning lights with 3D LED
  • BCS Powervalve TBE Prestige system with 200 cell cat and wrapped DP
  • LOBA's HPFP
  • CTS Turbo intake manifold runner flap delete kit
  • CTS Turbo throttle pipe
  • CTS Turbo turbo outlet pipe
  • Forge Motorsport oil catch tank system for vehicles with charcoal filter (FMMK5CTC)
Still not ordered:
  • Custom stage 2 remap
  • Custom DSG remap
  • Brembo Z8 calipers with 350 mm GL450 discs
  • HEL braided front brake lines
  • ATE SL.6 DOT4 brake oil
  • Bluemotion rear axle lining (1K0825206A & 1K0501713D)
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #21 on: April 26, 2015, 03:36:52 am »
And I need replace the wiper blades inserts and to get a new battery. :sad1:
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #22 on: April 27, 2015, 12:20:24 pm »
This weekend had some time to fit some of the parts that I have at home. :smiley:
Work done:
  • Bluetooth kit upgrade (7P6035730J) with adapter module Polar BT/Battery (PB01)
  • Complete interior LED set (6000K)
  • OEM rubber mats
  • Replaced the wiper blades inserts
Sunday morning the engine didn't want to start so I had to go buy a new battery. Fitted one with 74Ah 680A.
Here are some photos of the work done:
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #23 on: April 29, 2015, 10:55:58 pm »
Offline tom89
« Reply #24 on: April 30, 2015, 05:41:22 am »
Very nice car, especially in white.
Can you tell me why you are fitting R32 bump stops?
08 MKV GTI 3dr Manual K04
Offline teo_parvu
  • -Given: 30
  • -Receive: 57
« Reply #25 on: April 30, 2015, 06:58:30 am »
Love this! MKV is the best Golf and ED30 is it's best version. K04 has a huge tuning potential.
Great ride!  :congrats:
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #26 on: April 30, 2015, 12:26:59 pm »
I chose the R32 bump stops because they're a bit shorter than the regular ones, since I'm replacing my lowering springs and dampers. I hope they're more adequate to that setup. :smiley:
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #27 on: May 02, 2015, 03:17:20 am »
Received two boxes, one with almost all of the rest of the parts that I ordered from Bold Sport and the other with the CTS Turbo bits. :smiley:
List update:
At home:
  • Koni Sport shocks
  • H&R Sport springs (29176-1)
  • RNS-510 P version
Ordered:
  • LOBA's HPFP
Still not ordered:
  • Custom DSG remap
  • Brembo 18Z calipers with 350 mm GL450 discs
Fitted the LED brake and parking lights today:
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #28 on: May 08, 2015, 08:12:45 pm »
Got this today on the mail:
Fitted one of these on the reverse light:
For the LED to work I had to exchange the wires in the connector. It wasn't that easy to release them from the plug. :sick:
Offline Saj
« Reply #29 on: May 09, 2015, 01:52:39 am »
Nice car mate!
