Author Topic: Engine warning light faulty thermosat sensor  (Read 1396 times)
LukeC
« on: June 22, 2015, 02:38:29 am »
My engine warning light has come on and its related to a faulty thermostat sensor - my local guys who service it diagnosed it for me.
There is nothing wrong with the car - not over heating etc. The mechanic has said that it is fine to drive but to get the light to turn off will require changing the thermostat. Which is a pretty costly part and the labour required would be a few hours, as its in a difficult to access area of the engine.
Does anyone have any suggestion on how to get the light turned off without changing the part? I don't want to spend money needlessly, when it is just a faulty sensor.
Offline RedGolfDom
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99951.0.html
Re: Engine warning light faulty thermosat sensor
« Reply #1 on: June 22, 2015, 10:00:27 am »
The thermostat is only about 30 quid but labour is a lot, there are guides on to change it if you feel like you can it is a tough job though but saves you about 400 quid or whatever they will charge to fit
Mk5 golf gt 140
Revo stage 1
Air lift Performance 3p
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #2 on: June 22, 2015, 10:18:18 am »
Makes no sense to me. The thermostat is a mechanical part that controls the cooling of the car - it is not a sensor. If it were faulty the car would overheat or never warm up at all.
Are you sure it's not the coolant temperature sensor that you need to replace?
  • -Receive: 453
« Reply #3 on: June 22, 2015, 10:31:54 am »
Let's be certain on what the issue is here before doing anything!
Get a vcds scan from a forum member near to you http://www.mk5golfgti.co.uk/forum/index.php/topic,88875.0.html and post up the fault codes/issues.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #4 on: June 22, 2015, 12:22:27 pm »
Don't like to doubt a mechanic but the issue with the thermostat is a common issue and wouldn't cause the engine management light to come on.
Yes you may have a thermostat issue also but that engine warning light shouldn't be left idle.
Scan it yourself and get a print out, don't rely on that mechanics word.
