Author Topic: What diverter valve?  (Read 6035 times)
Offline Airz182
« on: June 26, 2015, 04:13:53 pm »
Recently car has been feeling laggy, and sounds like its got a dump valve. I replaced a leaky intercooler pipe which i thought was the problem, noise is still there,  So guessing the divertor valve has gone, last time i checked it i think it has got the revision G, is there a better one to buy, or should i go for the same one again?
Instagram- airz182
Offline MrACD
Re: What diverter valve?
« Reply #1 on: June 26, 2015, 04:30:31 pm »
I've been looking loads and reading loads into this, from what I can see the tuners etc all say that the revision G is the best one out of the bunch to get, holds the best boost.  Some people change their DV valves once a year with a service.
I was looking into getting the DV+ but even that leaks apparently, so it goes back to the Rev G.
2005 Gti - 5dr, DSG, Black
2003 Toyota MR2 Roadster, Chilli Red
2005 Honda VFR800 Vtec
Offline Airz182
« Reply #2 on: June 26, 2015, 04:46:57 pm »
I did read that G was the best but that was sometime ago, i had a quick scout on ebay and one was a D and said it was the latest one?
Instagram- airz182
Offline MrACD
« Reply #3 on: June 26, 2015, 04:59:52 pm »
The D is the gate one, leaks quite a lot that one does, doesn't fail but doesn't hold very well (so I read lol).
I've ordered the Rev G from Awesome, changing once a year ain't no issues.
Offline Airz182
« Reply #4 on: June 26, 2015, 05:06:02 pm »
I live round the corner from awesome, how much was the valve mate cheers
Instagram- airz182
Offline Matthewsimone
  • -Receive: 39
« Reply #5 on: June 26, 2015, 05:44:46 pm »
Rev G
£41 from Vw  :happy2:
Offline MrACD
« Reply #6 on: June 26, 2015, 06:24:29 pm »
£43
Offline markos
« Reply #7 on: June 27, 2015, 12:32:45 am »
I'd go for the gfb dv+... Loads of happy users and there's been no leak for a couple of years apparently. The old one used to leak but they revised and replaced the crappy old one. New one is awesome imo
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #8 on: June 27, 2015, 04:59:45 am »
You should be set with a version-G.
I've been using an AWE DV( http://www.awe-tuning.com/awe-b8-dv )...it is a vacuum-operated Porsche DV. It has been spot on even when my boost exceeded 25psi with a past tune.
Offline th3_f15t
  • -Receive: 183
« Reply #9 on: June 27, 2015, 09:04:31 am »
That looks like a good bit of kit. Got a picture of it fitted up? Also, is it for both K03 and K04 turbo engines?
Offline Airz182
« Reply #10 on: June 27, 2015, 10:01:15 am »
Im just going to go with revision G again,
Instagram- airz182
Offline ReflexRob
« Reply #11 on: June 27, 2015, 10:56:00 pm »
I'm really surprised so far with what owners are expecting to cover once a year during a service; that's now a £40 DV and a £40 cam follower every 10k excluding basic service items! That's ridiculous.
My old 93 MR2 turbo with 275bhp running an HKS BOV never needs stuff like this!
Surely there is a realistic long term solution for the DV?
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #12 on: June 29, 2015, 10:11:28 pm »
You can run both oem or their DV on this DV relocate kit when upgraded from a K03 to a K04, but not sure if their DV will fit where the oem K03 DV is. I would assume it would since both fit the relocate kit, but then there's the location and the heat involved being turbo mounted on a K03.
