Author Topic: Mk6 climatronic problem  (Read 6146 times)
Offline 99hagued
« on: July 05, 2015, 11:41:51 pm »
Just fitted a mk6 climatronic unit from bold sport to my 07 edition 30, did the pin 16 to 20 swap and it seems to work did the basic setting using the buttons and the ac kick in but when I go into vcds its throwing up 'No Signal/Communication - Intermittent' on both the CAN gateway and Auto HVAC, and when I try to go into Auto HVAC it says 'No Response From Controller'. Could this mean I need the newer CAN Gateway to communicate with the newer climatronic as mine being the pre 57 plate has the older 7N0907530K CAN gateway.
Any help would be much appreciated
Offline K9
  • VW LifeStyle
Re: Mk6 climatronic problem
« Reply #1 on: July 05, 2015, 11:45:30 pm »
Guess it will need a newer version of it. Myself i have a AL 2014 version gateway and will be doing the exact same as you on my 2005 gti
Writen with my fingers
Offline 99hagued
« Reply #2 on: July 05, 2015, 11:51:34 pm »
Where did you get it from and how much if you don't mind me asking
Offline K9
  • VW LifeStyle
« Reply #3 on: July 06, 2015, 12:02:33 am »
Not the same version as i got but this is what i found http://www.ebay.co.uk/itm/Skoda-VW-OEM-CAN-BUS-GATEWAY-7N0-907-530R-7N0907530R-7N0907530-/221149424737?hash=item337d886c61
Offline Softishman
« Reply #4 on: July 06, 2015, 11:12:40 am »
Had the same problem, new can gateway fixed it!
Offline 99hagued
« Reply #5 on: July 06, 2015, 01:42:49 pm »
Thanks for the input guys just ordered one off fleebay for £30 from Poland, its a 7N0907530AK so fingers crossed it will work because I have noticed that although the ac work after a few minutes the vent stop blowing air out so think it needs setting up with vcds.
Offline Softishman
« Reply #6 on: July 06, 2015, 10:43:21 pm »
That problem i also had!!! To fix that you have to solder the two flaps in parrallel, this connector!
To this
Hope you can see the colours on the wires!!!
After that everything is ok!!!
Offline 99hagued
« Reply #7 on: July 11, 2015, 08:47:28 pm »
Ok so im going to be fitting the new can gateway tomorrow and doing the wire swap. Do I need to swap on the brown (C) connector pin 7 to 10 and pin 8 to 9 ??
what about the black (B) connector do I need to swap pin 7 to 8 ?? also any tip for coding the can gateway as it came from Poland so will be lhd.
Offline Softishman
« Reply #8 on: July 12, 2015, 08:39:13 am »
Do you have vcds? Check the old can gateway in vcds and take pictures of everything! Then simply change the can gateway and check the same boxes that the old one had checked.
On the black connector (picture on my last post) you move 7 and 8 to ? And ? , don't remember the numbers but you can see the wire colours! That is for parrallel connecting the two vents so air could come front mid dashboard.
Offline Softishman
« Reply #9 on: July 17, 2015, 08:20:30 am »
Have you fixed the problem yet?
Offline 99hagued
« Reply #10 on: July 18, 2015, 06:56:25 pm »
Ok so iv fitted the can gateway and coded it no problems and iv connected the two flaps in parallel so the vents now open when ac is on. There's a few problems I have noticed, when the ac is on the vents are like blowing faster and slower?, the recirculation doesn't seem to do anything when pressed?(I bought the version without auto recirculation) and I have a few faults stored in Auto HVAC,
13701424 - function restricted due to missing message(s)?
13701456 - function restricted due to missing message(s)?
one other thing is the fan on the lowest setting is still quite fast?. How does everyone elses compare who have this fitted in a pre 57 with two flaps,
does any one know if doing the other wire swap in the small black terminal (On B Connector (black): Pin 6 to Pin 7) would cure any of my problems?
« Last Edit: July 18, 2015, 07:01:45 pm by 99hagued »
Offline 99hagued
« Reply #11 on: July 20, 2015, 12:28:05 am »
Been doing some more homework and iv found the fault codes are because I need newer dials and BCM I can live with that. iv been reading on the skoda forums http://www.briskoda.net/forums/topic/277700-step-by-step-retrofit-fl-climatronic-module-to-prefl/  (same setup as the golf) its seems if you have a two flap heater system found in the pre 57 golf then the mk6 climatronics wont function 100% the recirculation wont work, I can live no recirc but the noise it makes when ac is on needs sorting its like the flap inside is opening and closing making the air flow sound faster and slower, so going to try and play with the connector B (black) see if I can fix that.
