Author Topic: Is it Normal for car to run badly after Decat before map?  (Read 1860 times)
Offline wilsy_
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,86723.msg952943.html#msg952943
« on: August 02, 2015, 05:44:23 pm »
So I fitted my BCS decat yesterday with the intention of going stage 2 in the next week or so.
As expected the engine light came on, but the car is also running a bit strange. Under 3000 revs it almost seems to be like shaking?
I scanned for fault codes and it came up with 5? Are these all normal for when fitting a decat? I feel like they arn't!!  :sad1:
00305 - Fuel Consumption indicator signal - sporadic 002 - lower limit exceeded
00768 - Rear Heater core temp sensor (G154) - sporadic 002 - lower limit exceeded
00769 - Coolant temperature sensor at engine outlet (G82) sporadic 002 - lower
00770 - Coolant temperature sensor at radiator outlet (G83) sporadic 002 - lower
00771 - Fuel Level Sensor (G) sporadic 002 - Lower limit Exceeded
Thanks in Advance!
Ryan
« Last Edit: August 03, 2015, 09:51:12 am by wilsy_ »
Offline xjay1337
  • -Receive: 377
Re: Is i tNormal for car to run badly after Decat before map?
« Reply #1 on: August 02, 2015, 06:34:18 pm »
"My mechanic changed my brakes and now the engine developed a mis-fire"
None of those codes are related to the decat pipe.
I had absolutely no issues when fitting my decat pipe aside from an engine light which came on about 2 days later.
Unless your mechanic completely bodged the fitting and broke all of the other sensors or left something unplugged. Literally you only need to undo the 4 bolts on the downpipe and a few under the car :) and the lambdas !
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #2 on: August 02, 2015, 06:59:39 pm »
Problem is you don't know what codes were already there. Clear them all and see what comes back.
Offline wilsy_
Re: Is it Normal for car to run badly after Decat before map?
« Reply #3 on: August 03, 2015, 09:54:30 am »
Thats what I thought  :sad1:
Car had no fault codes before, so the unrelated ones must be coincidence, or something has got hit/broken when fitting the exhaust. The two lambdas where the only sensors removed, and they been fitted back correctly.
Offline th3_f15t
  • -Receive: 183
« Reply #4 on: August 03, 2015, 02:21:43 pm »
Check all the fuses and just double check all the sensors are firmly seated and clear from any debris.
