Author Topic: Engine Cover  (Read 3325 times)
Offline irish_ram
  • -Given: 200
Engine Cover
« on: August 19, 2015, 08:29:41 pm »
Has anyone modded their existing Engine cover to fit around a CAI. I have fitted a Ram Air intake as below and wondering how dificult it is to mod the existing cover
Re: Engine Cover
« Reply #1 on: August 19, 2015, 08:43:53 pm »
Lots have moded their OEM Covers. Just a quick search....
http://www.mk5golfgti.co.uk/forum/index.php/topic,11138.0.html
.....AND clean your bay, looks like a sandpit!!  :signLOL:
Offline irish_ram
  • -Given: 200
Re: Engine Cover
« Reply #2 on: August 19, 2015, 08:47:51 pm »
Thanks and yes it needs a clean. As you noticed can you recommend a good cleaning method as I presume a powerful jet spray can be dangerous
Offline sanj
  • -Given: 17
Re: Engine Cover
« Reply #3 on: August 19, 2015, 08:56:57 pm »
Get a Audi TTS engine cover and get it modded it look's the dog's,here's mine.
Offline irish_ram
  • -Given: 200
Re: Engine Cover
« Reply #4 on: August 19, 2015, 09:04:20 pm »
Does look good but I would say the cover cost a bit initially
Re: Engine Cover
« Reply #5 on: August 19, 2015, 09:04:40 pm »
^^^ Like that............(I would, it looks exactly like mine!  :laugh:). They are about £100 inc fitting bolts.
Jet wash will be fine.
Use any APC and agitate with a brush then jet wash off. If your worried about Battery, fuse box, CAI filter etc then cover with a plastic bag.
Run the engine first to warm up and also after to help dry out IMO.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: Engine Cover
« Reply #6 on: August 19, 2015, 09:44:37 pm »
I did using a Dremel with cutting disc...don't worry about the melting...it will peel off quite easily afterwards:
You want to leave the two rear mounts and take away only what you need to for clearance and if needed add support for future removal:
« Last Edit: August 19, 2015, 09:46:38 pm by ROH ECHT »
