Author Topic: Problems after ABS Pump Fix [FIXED]  (Read 19288 times)
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« on: September 16, 2015, 07:37:12 pm »
So I finally got around to fitting the ABS Pump fix kit this evening (been sat in the cupboard since last year :ashamed:), all went well (hopes)...
cleared the VCDS error and didn't come back (which it used to immediately)... didn't have time to bleed the brakes, but have one of those EZ Bleed kits to do tomorrow morning...
Just wondering, what is the best order to bleed on the GTI?  Nearest to the Master Cylinder and away, so Front Right / Front Left / Rear Right / Rear Left?
Have done it before AGES ago 5 years or so, but forgotten and have been relying on VW to do it since, so it would great to know, cheers. :)
« Last Edit: September 23, 2015, 04:55:58 pm by Scottymon »
Offline Mitch H
  • -Receive: 25
Re: Brake Bleed Order after ABS Pump Fix
« Reply #1 on: September 16, 2015, 07:49:58 pm »
Thought it was opposite mate furthest away from reservoir first
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #2 on: September 16, 2015, 08:01:28 pm »
Thanks mate... there seems to be a lot of different thoughts on the net for the Mk5 GTI - I'm not 100% sure
Offline omeydz
  • -Receive: 50
« Reply #3 on: September 16, 2015, 08:02:12 pm »
Front left, front right, rear left, rear right, clutch slave according to VW manuals
Recently back on the forum! Good to be back
Current Rides
Mazda RX8 231bhp ( very different little rocket lol!)
SOLD
2007 MK5 Golf 1.4 FSI
2007 Golf MK5 GTI DSG
2008 Audi A5 3.0TDI
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #4 on: September 16, 2015, 08:11:53 pm »
Cheers mate... blimey... right, I guess I should go with the VW Manual... unless anyone else thinks any differently?  LOL.
Offline dronners
« Reply #5 on: September 16, 2015, 08:27:10 pm »
i've always been taught to work from furthest to closest. but you cant really argue with the VW manuals lol
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #6 on: September 17, 2015, 06:03:51 pm »
Well I did the VW method, and the pedal seems good and stopping power is definitely better.
However, after clearing the codes, they didn't come back, but have a different ABS code now (sigh) and traffic light dashboard :(  Could this mean the ABS needs coding of some description?
Here's the error:
1 Fault Found:
01316 - ABS Control Module
Ross Tech Wiki says: http://wiki.ross-tech.com/wiki/index.php/01316
Which suggests a wiring / comms issue... the main plug behind the pump is definitely seated well.
I used the VW Fix kit which has fixed the G201 error, does the above mean the other half is now fecked?
MOT next week too, haha.  HELP, hugely appreciated :)
Offline doylebros
  • -Receive: 310
« Reply #7 on: September 17, 2015, 06:06:27 pm »
Here's the error:
1 Fault Found:
What warning lights are on the cluster after the scan and DTCs cancelling?
Offline doylebros
  • -Receive: 310
« Reply #8 on: September 17, 2015, 06:10:00 pm »
Have you performed the basic settings as per this section 03
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Brake_Electronics_(MK60)#Basic_Setting
If not you need to.
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #9 on: September 17, 2015, 06:17:52 pm »
Here's the error:
1 Fault Found:
Hi mate thanks for the reply.
After immediate clear via VCDS I get the ESP and Tyre Pressure signs on the cluster (Ignition/Startup).
But when moving off, 10-20mph perhaps, I get an additional ( ABS ) warning sign, as well as the above.
The Rosstech wiki shows comms issue, but I was Really careful to cover/wrap both plug and socket of the connecters with clean disposable gloves as I thought fluid may get on them - I'm pretty confident the connection is clean and sound.
Tad annoying really, as I thought I was golden, lol.  Any suggestions :)
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #10 on: September 17, 2015, 06:18:39 pm »
If not you need to.
I have not.
But I bloody well will do mate...  Thanks :) Will check back.  :happy2:
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #11 on: September 17, 2015, 08:11:36 pm »
:( No joy mate.
When activating BASIC SETTINGS via clicking the Button highlighted in green below, my response is: ERROR: Group 66 Not Available
Brake Pressure Sensor 1 (G201)
Prerequisites:
    System voltage at least 12.0 V.
[Select]
[03 - Brake Electronics]
[Measuring Blocks - 08]
Group 005
[Go!]
Check field 1, the value has to be between -8.0 and +8.0 bar.
[Done, Go Back]
[Coding-II - 11]
OR (if Coding-II is not available)
[Security Access - 16]
Enter 40168, to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Group 066
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
After a successful basic setting, field 2 should say "OK".
[Done, Go Back]
To make sure the basic setting was successful, check the sensor again.
Group 005
[Go!]
Check field 1, the value has to be between -3.8 and +3.8 bar.
[Done, Go Back]
[Close Controller, Go Back - 06]
Bugger :(  What do peeps think from here? :)
Worth noting the Orange line from above the test comes back within the specified range...?
Offline doylebros
  • -Receive: 310
« Reply #12 on: September 17, 2015, 08:19:15 pm »
Are you following the set up for your model of pump?
I know the last one I done was a right chew for it to accept the security code!
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #13 on: September 17, 2015, 08:26:56 pm »
I think so mate... it's accepting the Security Code (40168), then onto Basic Settings 04, but once in there and clicking the Activate button at the top, it spreads the: ERROR: Group 66 Not Available across all the field boxes in red/maroon.
That's as far as I've managed to go, as the instructions then say: After a successful basic setting, field 2 should say "OK".
DOH.
Offline doylebros
  • -Receive: 310
« Reply #14 on: September 17, 2015, 08:34:06 pm »
This is very similar to the issue I had see if this helps you.
Read this all but section 5 pre ABS bleed is what you need to address first
http://www.andrewhope.co.uk/automotive/techdocs/g201_brake_sensor_repair.html
