Author Topic: Gti front grill  (Read 2634 times)
Offline Vwgtiking
Gti front grill
« on: December 20, 2015, 03:56:26 pm »
Just had a little look around mine today to see what's what, and have noticed there are no screws nr the number plate that secure it. I can see the holes BUT I can't see how the screws are secured. Do they use those metal clips?
On the top I can see that on either side of the bonnet latch there are retaining clips that look broken and have been replace by screws. I assume the 2 that should be by the number plate and the 2 outer screws have been self tapped to secure and not using the pre existing holes. Again, I cant see how these screws are secured into the correct holes?
Just trying tidy up all the previous owners bodges.
Pics would great so I got an idea how they fit. Or maybe a nut and bolt job.
Offline th3_f15t
  • -Receive: 183
Re: Gti front grill
« Reply #1 on: December 20, 2015, 10:30:16 pm »
There are 4 screws for the stock grill:
2 in the top, torx fitting
2 at the bottom, securing into metal retaining clips.
The grill also uses tabs to clip into place for extra securing. Hope this info helps mate.
4ndy
Re: Gti front grill
« Reply #2 on: December 20, 2015, 10:34:09 pm »
U clips or speed nuts
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Gti front grill
« Reply #3 on: December 20, 2015, 10:36:56 pm »
They are called spire speed fasteners and there should be two behind the no plate to secure the lower part of the grill in.
2 x philips screws lower and 2 x torx t25 I think it was for the top.
Offline Vwgtiking
Re: Gti front grill
« Reply #4 on: December 21, 2015, 08:19:17 am »
Thanks for replies. I can't see how the top screws are retained as there is just a hole.
4ndy
Re: Gti front grill
« Reply #5 on: December 21, 2015, 08:27:05 am »
Top is plastic thread and needs replacing with rivnuts  I'm sure I used 5mm ones with dome headed screws( I have some spare). Stainless will be best
 Tricky if you have fat fingers but once done its a long term fix
« Last Edit: December 21, 2015, 08:28:54 am by 4ndy »
Offline Vwgtiking
Re: Gti front grill
« Reply #6 on: December 21, 2015, 09:02:12 am »
Many thanks.
