Author Topic: Rear Badge  (Read 5660 times)
Offline ED30Girl
Rear Badge
« on: January 25, 2016, 01:42:21 pm »
What are the best products to use to paint my rear badge on a ED30?
Want to do the backing in Tornado Red and the Badge gloss black. :happy2:
Offline cenobytez
Re: Rear Badge
« Reply #1 on: January 27, 2016, 12:42:11 pm »
I used halfords spray cans on mine...
Offline ED30Girl
Re: Rear Badge
« Reply #2 on: February 01, 2016, 11:57:11 am »
Did you spray the backing underneath the badge black ? I'm not too worried about doing the badge itself just don't know how to go about doing the back in red.
Offline cenobytez
Re: Rear Badge
« Reply #3 on: February 01, 2016, 12:11:49 pm »
yes, i bought plastic primer, the pearl black magic and the red, and of course, lacquer.
split the badge, rubbed down using fine wet and dry, painted several coats of primer, allowing time to dry between each.
then painted the relevant colour, several coats, finishing of with 1x coat of lacquer.
re-assembled the badge. This needed a little help, as the slots for badge were now slightly smaller due to the paint.
Re: Rear Badge
« Reply #4 on: February 01, 2016, 12:27:37 pm »
Ive had few over the years, remove the emblem and prep,undercoat,paint and lacquer the backing, ideally remove the whole mech as this makes the whole process a lot easier. If you are not to bothered thrm simply wrap the backing.....
Black on red with Mk5 3D emblem...
Crhome on red with Mk6 3D beveled emblem......
Offline SiimpleHarry
Re: Rear Badge
« Reply #5 on: February 01, 2016, 02:15:26 pm »
I had my badge done in black for a fiver from a vinyl car wrapper. Looks great and can be removed later on if you change your mind!
Offline ED30Girl
Re: Rear Badge
« Reply #6 on: February 09, 2016, 09:32:50 am »
Thanks Guys! I'll let you know how i get on  :grin:
Offline ashvag0
  • candy white gti
Re: Rear Badge
« Reply #7 on: February 21, 2016, 05:55:19 pm »
Plastidip works well also, plus if your not too keen on the outcome it comes off easy enough
Offline damo24
Re: Rear Badge
« Reply #8 on: March 30, 2016, 09:02:22 am »
Quick question if I may - I am in the process of spraying mine:
Did you sand the paint before applying the lacquer?
The instructions on the lacquer can say to do so but Google throws up conflicting advice
Offline cenobytez
Re: Rear Badge
« Reply #9 on: March 30, 2016, 09:06:37 am »
not on the last coat of paint prior to lacquer, light inbetween coats of paint, but not after the final coat of paint.
Offline damo24
Re: Rear Badge
« Reply #10 on: March 30, 2016, 10:18:54 am »
Perfect thanks mate
