Author Topic: Part???  (Read 15639 times)
Offline irish_ram
  • -Given: 200
Part???
« on: January 28, 2016, 03:40:42 pm »
Can someone help me in identifying what this part is please and how much to replace as the connector has snapped as shown in the picture
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
05 | Tornado Red | DSG
Offline irish_ram
  • -Given: 200
Re: Part???
« Reply #2 on: January 28, 2016, 04:21:42 pm »
camshaft adjustment valve N205
think this is the part number 06F109257C
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1725&ein=2005&f=420&hauptgr=1234567890&hg=1&grf=010355420&bf=10355&hgug=103&ug=03&parent_id=2007824&detail_id=2007887
Nice one, cheers
Do you know what problems it would cause if this was not working as apart from the snapped connector which I glued back on I have not noticed any issues with the car
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: Part???
« Reply #3 on: January 28, 2016, 04:23:05 pm »
Do you have VCDS? I'm sure it would throw an error if it was fooked.
Offline irish_ram
  • -Given: 200
Re: Part???
« Reply #4 on: January 28, 2016, 04:26:13 pm »
I do and just being Lazy, will nip out now and see what pops up  :happy2:
Offline irish_ram
  • -Given: 200
Re: Part???
« Reply #5 on: January 28, 2016, 05:00:43 pm »
So did a scan and there are errors but nothing around this. Only errors popping up are below to confirm they are nothing to do with this valve
Address 09: Cent. Elect.       Labels: 3C0-937-049-23-H.lbl
Control Module Part Number: 3C0 937 049 AE    HW: 3C0 937 049 AE
  Component and/or Version: Bordnetz-SG     H52 2002
           Software Coding: E78F8F271004151E471400001400000000187F07480001
            Work Shop Code: WSC 12345 785 00200
           Additional Info: 1K2955119E  Wischer 151106 020  0501   1K0955559AB RLS     201106 020  0105
                      VCID: 6CD7223B4F7E2C7E58B-8039
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 155
                    Mileage: 125260 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 11.45 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K6 920 973     HW: 1K6 920 973
   Component: KOMBIINSTRUMENT VDD 1610
   Revision: V0003000    Serial number: VWZ7Z0F8211388
   Coding: 0005403
   Shop #: WSC 65536 645 12345
   VCID: F0EFB64BE356489EE43-80A5
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 155
                    Mileage: 125260 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:37:25
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0020
   Revision:   H04 02    Serial number: 201106F1001388
   Coding: 7F8F034007000001
   Shop #: WSC 01279 785 00200
   VCID: 2F6DF537BEE897663D9-807A
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 155
                    Mileage: 125260 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:37:44
Offline doylebros
  • -Receive: 310
Re: Part???
« Reply #6 on: January 28, 2016, 06:46:06 pm »
It's item 30 http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1728&ein=2007&f=474&hauptgr=1234567890&hg=9&grf=091940249&bf=91940&hgug=919&ug=19&parent_id=2361269&detail_id=2361295
Used to alter the camshaft timing!
You need the part number off the contractor/connection which you'll be able to buy just that bit!
Offline irish_ram
  • -Given: 200
Re: Part???
« Reply #7 on: January 28, 2016, 07:01:56 pm »
Cheers so you think I could just replace the snapped connector which is fitted on the top of the valve and not have to replace the whole part. From my VCDS scan it seem it is not causing an issue at the moment maybe but by the state of the connector it will eventually go
Offline doylebros
  • -Receive: 310
Re: Part???
« Reply #8 on: January 28, 2016, 07:04:03 pm »
Offline doylebros
  • -Receive: 310
Re: Part???
« Reply #9 on: January 28, 2016, 07:05:58 pm »
To me I thought it was the connector not the valve if it's the valve that's broken there not cheap few hundred pounds comes to mind!
Offline doylebros
  • -Receive: 310
« Last Edit: January 28, 2016, 07:11:09 pm by doylebros »
Offline irish_ram
  • -Given: 200
Re: Part???
« Reply #11 on: January 28, 2016, 07:13:16 pm »
Cheers but it is the connector attached to the actual valve that had snapped and I glued back on
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: Part???
« Reply #12 on: January 28, 2016, 07:14:34 pm »
Maybe create a topic in the wanted section you never know.
Offline irish_ram
  • -Given: 200
Re: Part???
« Reply #13 on: January 28, 2016, 07:15:36 pm »
Yeah think I will or try and find someone breaking an MK5
Offline irish_ram
  • -Given: 200
Re: Part???
« Reply #14 on: January 28, 2016, 07:17:02 pm »
Look here it's know as the N205 valve price one on eBay this is the how to http://workshop-manuals.com/volkswagen/golf-mk5/power_unit/4-cylinder_injection_engine_(2.0_l_engine_direct_injection)/engine_cylinder_head_valve_gear/valve_gear/removing_and_installing__inlet_camshaft_control_valve_1_n205/
Price for one I found https://jhmotorsports.com/shop/catalog/valve-or-solenoid-for-camshaft-adjustment-n205-oem-for-20t-fsi-b7-a4-gti-more-p-2471.html
Before I glued it back together I was getting the error the above link suggest as in
000010 - Camshaft Positioner (Bank 1 Intake) P000A - 008 - Slow Response
But after I glued it and re-scanned it went so will probably last until I can get a replacement
