Author Topic: URGENT oil pressure stop engine  (Read 279004 times)
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #510 on: March 31, 2016, 10:54:28 pm »
Really is straightforward mate - just pay attention to the way the current one is routed, once removed just startfeeding it from the top down - rotating and twisting as needed to get it in to place, then they simply push on to the connector and click in to place
If you can take the top end of the engine apart, this pipe will be a doddle!
« Reply #511 on: March 31, 2016, 10:59:16 pm »
maybe  06F 103 235
double check it
Offline Pesky jones
« Reply #512 on: March 31, 2016, 11:21:02 pm »
Nice one rich looks right
« Reply #513 on: March 31, 2016, 11:22:25 pm »
BTW... what did you do about the rear pcv pipe?
Offline Pesky jones
« Reply #514 on: March 31, 2016, 11:24:07 pm »
Sorry rich not sure I follow? What about it?
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #516 on: March 31, 2016, 11:27:06 pm »
How did you re-attach it? OEM clip?
Offline Pesky jones
« Reply #517 on: March 31, 2016, 11:28:49 pm »
No I had two little screw tight clip type things that have done the job nicely.
I was.on that parts catalogue dan but it looks different and also gives a different part number. Think richs part number is the right one
Offline Pesky jones
« Reply #518 on: March 31, 2016, 11:46:58 pm »
FYI I reattached that hose before I reattached the valve cover. First of all I tried with the valve cover bolted up but struggled to get the hose seated so did it that way. I havnt seen it any guides so im not sure whether youre supposed to or not but you could try it if you get stuck.
« Reply #519 on: April 01, 2016, 12:09:29 am »
Ok. Will bear that in mind.  :happy2:
Offline Pesky jones
« Reply #520 on: April 01, 2016, 09:36:09 am »
Ive ordered that pipe at vw, but might just tape it up for now, untill ive done the compression test. If it comes back bad it will be the least of my problems
Offline Pesky jones
« Reply #521 on: April 02, 2016, 11:30:11 am »
Tried taping but its not a clean split. Got the tape on, put thr hpfp back on, tried to put the hose onto the pvc and it just seperated again :doh:
Mates picking me up and we're going to get the new one. Look at the block connection! Sludge plus wierd brown rocks
Offline Pesky jones
« Reply #522 on: April 02, 2016, 02:46:59 pm »
Replaced it fairly quickly, thoight it was going to be a pain.
Anyone know thE fuel pump fuse? Is it fuel pump relay or fuel pump lift?
Offline Pesky jones
« Reply #523 on: April 02, 2016, 03:50:37 pm »
Soooo compression test. Bang on 150 psi across all four cylinders.
Started it and it runs!!!!! Didnt sound bad tbh, only thing was after about 30 seconds it started to smoke. Smelt like burning rubber. No idea what it could be...?
Il post a video in a second
Offline Pesky jones
« Reply #524 on: April 02, 2016, 04:05:25 pm »
