Author Topic: URGENT oil pressure stop engine  (Read 279229 times)
Offline Pesky jones
« Reply #645 on: April 08, 2016, 02:47:17 pm »
Tfsi tuning is the fb group. Ill check block 93 tomorrow before I start redoing the timing. If it all goes to plan I might be able to get it all stripped back and timed up again by tomorrow eve
Offline Pesky jones
« Reply #646 on: April 09, 2016, 10:12:27 am »
heres a log from this morning. You can see block 91 actual starts to raise closer to 28kw (never gets there) when reving it.
not sure about block 93, heres the log
Offline Pesky jones
« Reply #647 on: April 09, 2016, 01:11:03 pm »
I cant get the locking tool to slide in between the two shafts :scared: definitely not in time.
Anyway is it possible to remove the adjustor bolt without the tool?
Offline doylebros
  • -Receive: 310
« Reply #648 on: April 09, 2016, 01:36:13 pm »
That thought is asking for trouble so NO!
Just see if you can use the inlet cam spanner to allow the locking tool to locate.
Offline Pesky jones
« Reply #649 on: April 09, 2016, 01:40:58 pm »
Haha didnt think so. Ok yeah have been doing that, ill keep trying. It was tight pulling it out last time so im not surprised its not going in nicely
Offline doylebros
  • -Receive: 310
« Reply #650 on: April 09, 2016, 01:41:54 pm »
Also post a photo showing the camshaft cut outs for the locking tool to locate when the engine is set at timing marks.
Offline doylebros
  • -Receive: 310
« Reply #651 on: April 09, 2016, 01:44:30 pm »
All the timing marks on the belt end set up aligned as expected didn't they?
Offline Pesky jones
« Reply #652 on: April 09, 2016, 01:48:52 pm »
Yes, although with the cambelt pulley no exhaust cam its hard to see if bang on because of the angle of the phone.
Offline doylebros
  • -Receive: 310
« Reply #653 on: April 09, 2016, 01:53:42 pm »
Explain the above I'm not understanding you.
Offline Pesky jones
« Reply #654 on: April 09, 2016, 01:56:48 pm »
I have to use my phone camera to see the exhaust camshaft pulley timing marks as the cambelt cover obstructs the timing mark on the back plate. It looks like its lined up or very close but obviously as my move my phone the angle changes.
Looking at the camshafts the notches dont lool parallel to me
Offline doylebros
  • -Receive: 310
« Reply #655 on: April 09, 2016, 02:02:08 pm »
It all starts by getting the belt end 100% right to the timing marks - until you know they are as they should be no progress can be made, so no guessing or possibly or phone photos is enough I'm afraid it's a fu*ker but remove what's stopping you to confirm those marks are where they need to be but don't remove the belt.
Offline Pesky jones
« Reply #657 on: April 09, 2016, 02:13:11 pm »
I dont think I can remove the timing belt cover to be honest. I have to drain coolant, remove engine mounts and a lot lot more. Is this to make sure that the cambelt hasnt slipped?
I can get the crankshaft at tdc 100%
Can I not just keep turning the crankshat a little bit at a time and try to fit the tool in?
I think everything is in the right place, a.k.a the chain and belt are on the right teeth etc because the guy who had the same problem as me had similar readings in regard to block 91, and his was on the right teeth, the adjustor bolt just needed to be tightened whilst turning and holding the inlet cam towards the back of the engine
Offline vRSAlex
  • -Receive: 253
« Reply #658 on: April 09, 2016, 02:16:52 pm »
The curse of the AXX one piece belt cover!
You need will need to check the belt timing first.  Mirrors will help see the cam marks.  Then you will know if the inlet cam is a tooth out which going off the pic it looks to be a tooth forwards.
AXX when warmish should read around 45% and 24KW/24KW.
Follow AKS tuning on Facebook
Offline Pesky jones
« Reply #659 on: April 09, 2016, 02:24:07 pm »
Well I think id have the same problem with mirrors, it will look to be spot on but I cant be sure becauese of angles.
If it is a tooth out (it looks like the notches arent parallel which supports this) how do I remove the chain if I cant get the tool in because its a tooth out?
