October 17, 2026, 12:34:46 pm
All Things Mk5
Mk5 General Area
ABS / ESP / Tyre pressure lights on and ABS not working
Topic: ABS / ESP / Tyre pressure lights on and ABS not working (Read 1686 times)
Flint
Taking part
-Given: 17
-Receive: 1
March 30, 2016, 07:21:56 pm »
Hi All
A while ago I had the typical sensor issue on the drivers side rear wheel. Had the sensor and the bearing replaced and all was fine for 6 months. I've now got the sane fault code on the same wheel.
Should the ABS work with this issue? I tested mine today and mine isn't working.
markrtw
Taking part
-Given: 1
-Receive: 0
Re: ABS / ESP / Tyre pressure lights on and ABS not working
Reply #1 on:
March 30, 2016, 08:16:31 pm »
I've had similar issues. Its probably the ABS ring on the inside of the hub out of tolerance. If it's only 6 months old, take it back to the garage. Should have a years warranty.
Is the bearing genuine?
Flint
Taking part
-Given: 17
-Receive: 1
Reply #2 on:
March 30, 2016, 08:26:22 pm »
Yes it was a genuine vag bearing. Do you know if the ABS should still work with this issue?
Andy
Admin
Just look at my post count
-Given: 39
-Receive: 447
Reply #3 on:
March 30, 2016, 08:35:45 pm »
If the abs light is on then no
gttdi build thread
r32 build thread
markrtw
Taking part
-Given: 1
-Receive: 0
Reply #4 on:
March 30, 2016, 09:08:46 pm »
Yep - ABS light shows fault with the system. What is the error code? I guess its something like intermittent signal?
Flint
Taking part
-Given: 17
-Receive: 1
Reply #5 on:
March 30, 2016, 10:32:10 pm »
Thanks to you both.
Yep it's saying intermittent signal.
All Things Mk5
Mk5 General Area
