Author Topic: ABS / ESP / Tyre pressure lights on and ABS not working  (Read 1682 times)
Offline Flint
  • -Given: 17
« on: March 30, 2016, 07:21:56 pm »
Hi All
A while ago I had the typical sensor issue on the drivers side rear wheel. Had the sensor and the bearing replaced and all was fine for 6 months. I've now got the sane fault code on the same wheel.
Should the ABS work with this issue? I tested mine today and mine isn't working.
Offline markrtw
Re: ABS / ESP / Tyre pressure lights on and ABS not working
« Reply #1 on: March 30, 2016, 08:16:31 pm »
I've had similar issues. Its probably the ABS ring on the inside of the hub out of tolerance. If it's only 6 months old, take it back to the garage. Should have a years warranty.
Is the bearing genuine?
Offline Flint
  • -Given: 17
« Reply #2 on: March 30, 2016, 08:26:22 pm »
Yes it was a genuine vag bearing. Do you know if the ABS should still work with this issue?
« Reply #3 on: March 30, 2016, 08:35:45 pm »
If the abs light is on then no
Offline markrtw
« Reply #4 on: March 30, 2016, 09:08:46 pm »
Yep - ABS light shows fault with the system. What is the error code? I guess its something like intermittent signal?
Offline Flint
  • -Given: 17
« Reply #5 on: March 30, 2016, 10:32:10 pm »
Thanks to you both.
Yep it's saying intermittent signal.
