Author Topic: Swapping a DV to DV+  (Read 4714 times)
Offline Pesky jones
« on: May 06, 2016, 03:57:27 pm »
My mate is pxing his leon fr tomorrow, he has a dv+ fitted.
He has said I'm welcome to it :)
Is it just a case of removing my DV rev G, removing his dV+ and swapping the two? As in a straight swap?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Swapping a DV to DV+
« Reply #1 on: May 06, 2016, 04:02:24 pm »
 :happy2: pain in the  :booty: to do but yeah  :signLOL:
Offline Pesky jones
« Reply #2 on: May 06, 2016, 04:06:31 pm »
Why is it pain? When I swapped mine for a revg I thought it was straight forward?
I need to
remove mine,
remove his,
swap them
get both cars back to normal in an hour... doable?
Offline Dan648v
  • -Given: 28
« Reply #3 on: May 06, 2016, 04:24:39 pm »
On a ko4 car easily. Never changed a ko3 car tho....
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #4 on: May 06, 2016, 04:40:57 pm »
Maybe because mine had never been replaced and is a rev B so original from factory so the bolts were seized  me thinks. I couldn't reach it from under the car so wheel off arch liner off and then accessed it. 45minutes  :doh:
  • -Receive: 692
« Reply #5 on: May 06, 2016, 04:45:37 pm »
Yeah it's a pain on KO3 cars.   N75 replacement is 'fun' also.
Nice valve the DV+ though. Worth the effort  :happy2:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6 on: May 06, 2016, 04:59:15 pm »
It puts a cheshire cat grin on your face once you've taking it out for a drive  :smiley:
Offline Kieran1990gti
« Reply #7 on: May 07, 2016, 11:24:02 am »
Would use say there is a performance gain even over a rev g. Very interested in these never heard of them either until this thread
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #8 on: May 07, 2016, 11:52:14 am »
Not a performance gain no, it seals just as well as a rev G. Improvements in throttle response and drivability are very noticable though
« Reply #9 on: May 07, 2016, 12:05:07 pm »
It's strange how it can improve throttle response and drivability so drastically. Does it reduce intake flutter?
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #10 on: May 07, 2016, 04:06:31 pm »
Flutter? Are you K03 or K04?
Not strange really. If you read up on how they work and the design of them it makes sense to me.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #11 on: May 07, 2016, 04:30:14 pm »
Don't fit it as your car will blow up and then you're feckled  :doh:
Offline th3_f15t
  • -Receive: 183
« Reply #12 on: May 07, 2016, 08:42:30 pm »
I ran one of these and had no issues. It's a straight swap for a stock DV. Did he buy it before or after GFB revised the design due to a flaw? They offer to send out the replacement bits if yours is one of the early, flawed designs.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #13 on: May 07, 2016, 10:13:42 pm »
Revised version has a black piston and stronger spring for anyone who would like to know the difference.  :smiley:
  • -Receive: 692
« Reply #14 on: May 09, 2016, 09:33:14 am »
Mine has a brass piston with orange seal.  Is that the older design?   There is a secondary, smaller, piston which is black though?   What was the actual flaw?
My car feels flat with the Rev G.  Due to the nature of the solenoid operation and the mapping, the valve is either open or closed.  The DV+ lets go of the waste pressure more progressively, which consequently makes the engine feel more responsive coming back onto the throttle after a dump.
