Author Topic: door  (Read 2404 times)
Offline stuupnorth
    • stuupnorth
door
« on: July 11, 2016, 05:49:00 pm »
hi all
this weekend I replaced the window regulator ie door skin off etc all went ok but
now I cant open the door from the outside or inside
any ideas?
Offline TAPPY
  • -Receive: 56
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,103290.0.html
Re: door
« Reply #1 on: July 11, 2016, 05:55:28 pm »
I believe the little cable you clip into the handle you have pulled it to tight when refitting
Offline stuupnorth
    • stuupnorth
Re: door
« Reply #2 on: July 11, 2016, 06:01:37 pm »
any idea how to solve the problem?
Offline TAPPY
  • -Receive: 56
Re: door
« Reply #3 on: July 11, 2016, 06:02:23 pm »
This bit in the pic.
Tricky but you will need to pull the outer handle about half way out roughly and use a small screwdriver to pop the cable / clip out and then open the door from inside then take out the lock cover out and re attach.
Offline TAPPY
  • -Receive: 56
Re: door
« Reply #4 on: July 11, 2016, 06:05:05 pm »
Let us know how you get on
Offline stuupnorth
    • stuupnorth
Re: door
« Reply #5 on: July 11, 2016, 06:15:45 pm »
Many thanks mate
as soon as you mentioned the little cable
I opened the handle and released the cable so I could open the door and then readjusted the cable
sorted again many thanks :happy2:
Offline TAPPY
  • -Receive: 56
Re: door
« Reply #6 on: July 11, 2016, 06:22:05 pm »
No worries mate I have seen it done loads of times and is a pita sometimes
