Author Topic: Can a cracked alloy be responsible for slow puncture?  (Read 3377 times)
Offline Max99
  • White GTi owner
« on: August 04, 2016, 04:52:56 pm »
So thought it was my tyre that had a slow puncture, but just had a new tyre fitted and same has low leak is happening
Is it likely a cracked alloy? That's all I can think it could be?
How much/where would I get a replacement alloy (it's 17" monza)
Offline Chris92
  • -Given: 33
Re: Can a cracked alloy be responsible for slow puncture?
« Reply #1 on: August 04, 2016, 04:59:51 pm »
Did they change the valve at the same time? Most likely that.
Long time since I've seen your name posting again
Offline bacillus
  • -Receive: 453
« Reply #2 on: August 04, 2016, 05:21:50 pm »
Get them to submerge the rim and inflated tyre in a drum of water.
Should show evidence of where the leak is...
Offline Stupots
  • -Given: 18
« Reply #3 on: August 04, 2016, 06:19:33 pm »
What condition are the alloys in? If you have flaking lacquer it will get under it no matter how much gunk they put on when they fit the tyre.
Good luck getting it sorted
2006 VW Golf Mk5 Sport TDI 4Motion (140 BKD)
Offline andyR43
« Reply #4 on: August 04, 2016, 07:15:16 pm »
Wheel could be buckled not necessarily cracked. :-)
Keeping it original..............or not!!
« Reply #5 on: August 04, 2016, 07:24:29 pm »
Could be
Rim leak
Puncture
Or
Valve
Offline Max99
  • White GTi owner
« Reply #6 on: August 04, 2016, 08:03:46 pm »
Cheers guys, know you'd shed more light on it!
I'll have take it to a garage and get them to find the problem!
