Author Topic: Fuel pump help  (Read 1549 times)
Offline RMK87
Fuel pump help
« on: December 06, 2016, 09:26:28 am »
Hi All,
Had my car in for a new chain and new value. Also had new gaskets etc. Turns out they didnt fit the fuel pump back on properly and its now loose on all 3 bolts! I can see it shaking away and car sounds rough as hell.
What damage can this cause?
  • -Receive: 692
Re: Fuel pump help
« Reply #1 on: December 06, 2016, 10:02:04 am »
Hopefully none if you nip the bolts up asap.  It's probably running rough because the pump piston isn't getting it's full stroke maybe.
Offline RMK87
Re: Fuel pump help
« Reply #2 on: December 06, 2016, 11:12:47 am »
Thanks for the reply.
Turns out one of the threads has broken and caused the other 2 to slip loose.
Temp fix applied, just need to find a replacement chain cover.
