Author Topic: Clunking from front end - steering rack or suspension??  (Read 9192 times)
Offline Edcase
« on: January 31, 2010, 09:44:37 am »
I reported before about some clunking from steering rack when manoevring at low speeds.
However now I've had the car longer I realise it's actually clunking also over any bumps, speed humps etc. even in a straight line.
Is this still likely the steering rack or could it be suspension related?
thanks
ed
Offline chip20
  • -Given: 35
    • http://absolutevaletinguk.co.uk/
Re: Clunking from front end - steering rack or suspension??
« Reply #1 on: January 31, 2010, 11:27:11 am »
Hi.Could be a number of things.Broken spring maybe or could be the anti roll bar bushes.Better getting it checked out.
Offline Edcase
« Reply #2 on: January 31, 2010, 12:09:45 pm »
Yeah think you're right - I was going to leave it when I thought it was just the noisy rack 'feature' but I get the feeling it's more than that.
Offline 182_blue
  • -Receive: 54
« Reply #3 on: January 31, 2010, 12:20:24 pm »
Is it all the time ?, or every now and again
Offline Edcase
« Reply #4 on: January 31, 2010, 12:41:36 pm »
All the time...every bump/speed hump etc.
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #5 on: January 31, 2010, 12:43:23 pm »
given its over bumps etc sounds like suspension.
top mounts , arb mounting points, broken spring etc.
Red ED35 5dr DSG
BLOG | BUILD
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
« Reply #6 on: January 31, 2010, 12:45:16 pm »
dogbones for the arb, i have just gotten new ajustable ones from Ksport
Over the top mod list ;o)
Offline Edcase
« Reply #7 on: January 31, 2010, 12:50:30 pm »
Right, will get this checked in next week. Thanks for the advice.  :smiley:
Offline TomB
« Reply #8 on: January 31, 2010, 07:03:29 pm »
Front wishbone rear bushes are also common on the MK5 platform.
A Whiteline anti lift kit or a new set from VW would cure that.  Best way to check is to get under the car with a lever and test the bushes.
Tom
05 GTI - 18" Merc wheels, coilovers, colour coded Votex kit, all waiting to go on.
Offline Edcase
« Reply #9 on: February 01, 2010, 11:48:05 am »
Incidentally the tyres I took off recently at the front were badly worn on the inside edges... is that likely to be related and does that narrow down what the clunking is likely to be?
Offline tony_danza
  • -Receive: 112
« Reply #10 on: February 01, 2010, 11:53:01 am »
That sounds like either wishbone bushes or topmounts. Either way something needs checking ASAP.
Sideways yo!
Offline 182_blue
  • -Receive: 54
« Reply #11 on: February 01, 2010, 12:24:59 pm »
when that happened on my old old car it was the wishbone bushes
Offline sixpot
« Reply #12 on: February 01, 2010, 02:36:07 pm »
I'd put money on it being the track control arm bushes. Mine were knackered, and caused a banging noise over every bump.
Offline 182_blue
  • -Receive: 54
« Reply #13 on: February 01, 2010, 06:32:37 pm »
how much are these ?
Offline Janner_Sy
  • -Receive: 113
« Reply #14 on: February 01, 2010, 06:38:11 pm »
bushes are normally cheap. its the labour that wil kill you as they are alwatys a pain in the ass
