September 06, 2026, 07:54:27 am
All Things Mk5
Mk5 General Area
CV Outer Boots + CV Joints Query
Topic: CV Outer Boots + CV Joints Query (Read 2326 times)
Raj2212
Always Involved
-Given: 75
-Receive: 20
My Ride:
February 23, 2018, 03:47:50 pm »
Advice needed
I'm after 2x Outer CV boots and 2x CV Joints - total on Eurocarparts is £81.71
Quoted about £80 Labour to fit.
Is that about right or can I get parts in for less
Any help is appreciated
neilw
Always Involved
-Given: 16
-Receive: 26
Re: CV Outer Boots + CV Joints Query
Reply #1 on:
February 23, 2018, 04:44:37 pm »
Sounds good. They are a bit of a pain to fit, so £40 aside is well worth it. I did my driver's side one and it took a good 2-3 hours.
You'll probably want to replace your hub/Driveshaft bolt, as they'll have to come out.
Last Edit: February 23, 2018, 04:47:05 pm by neilw
Edition30 #0002 R-Tech Stage2
Raj2212
Always Involved
-Given: 75
-Receive: 20
My Ride:
Reply #2 on:
February 23, 2018, 05:04:41 pm »
@neilw
Will add the driveshaft/hub bolts to the list.
pudding
Global Moderator
Just look at my post count
-Given: 2
-Receive: 692
Reply #3 on:
February 23, 2018, 05:42:11 pm »
If you get the GKN-Lobro CV joints from Carparts4less (ECP's sister site, but cheaper) they come with the OEM plastic boots, bolts, OEM clamps, grease etc.
Raj2212
Always Involved
-Given: 75
-Receive: 20
My Ride:
Reply #4 on:
February 23, 2018, 06:31:01 pm »
@Pudding
, new total with CP4L is now £68.54.
Unrelated to this but after some advice on getting a lower dogbone mount too. Should I get the ECS one
https://www.awesomegti.com/shop-by-brand/ecs-tuning/ecs-dogbone-mount-insert-kit-go5-eos-a3-jet-pasb6-leo2-oct2/
Or the Superpro ones, along with the smaller bush ?
https://www.awesomegti.com/shop-by-brand/powerflex/powerflex-lower-dogbone-mount-insert-kit-pff85-504-pff85-704/
https://www.awesomegti.com/shop-by-brand/powerflex/powerflex-lower-engine-mount-small-bush-pff85-505/
Saving up for the SuperPro WALK kit for now, but wanna get the dogbone mount in.
pudding
Global Moderator
-Given: 2
-Receive: 692
Reply #5 on:
February 23, 2018, 07:23:34 pm »
I'm not a fan of the inserts myself, I would get the 034 Motorsport ones personally, or the Vibratechnics if you can stretch to it -
https://www.awesomegti.com/shop-by-brand/034motorsport/034motorsport-density-line-dog-bone-mount-bushings/
Of the inserts I would probably go with the Powerflex yellow one. The small end one will add a fair bit of noise and vibration.
SuperPro Walk is a good move. Get the ones that add 1 degree of caster -
https://www.awesomegti.com/shop-by-brand/superpro/superpro-anti-lift-kit-for-mk5-mk6-golf-type-chassis/
Raj2212
Always Involved
-Given: 75
-Receive: 20
My Ride:
Reply #6 on:
February 24, 2018, 01:33:35 pm »
@Pudding
. Having read some reviews on the 034 Motorsport ones, its looking like they're a more perm fix. Price ain't too bad as well. Much appreciated. . Will add that to the list instead of getting the insert.
All Things Mk5
Mk5 General Area
