Author Topic: Racingline shocks and H&R springs  (Read 5522 times)
Offline Greeny
« on: December 14, 2021, 01:58:23 pm »
Does anyone know where the best place is to buy OEM Sachs shocks and top mounts?
Also, does anyone recommend the racingline performance shocks? Im looking at new shocks. I can't afford B12s or B8s, so it is either OEM or maybe the racingline ones for £375.
Cheers.
« Last Edit: January 30, 2022, 05:08:10 pm by Greeny »
Online pudding
  • -Receive: 692
Re: Shocks - OEM vs Racingline
« Reply #1 on: December 14, 2021, 04:28:18 pm »
Dealer or ECP.
Bilstein B4 are OEM equivalent and 50 quid each from Demon Tweeks.  That's probably what I would go for over the Sachs or Racingline personally.
Offline Greeny
« Reply #2 on: December 14, 2021, 05:04:44 pm »
I had read some bad things about the B4s.
Wonder how the Racinglines compare to them or the Sachs. Wouldn't mind spending up to the Racinglines but not the B12s haha.
Offline mjmallia
  • -Receive: 60
« Reply #3 on: December 15, 2021, 08:31:54 am »
I have the B4's and they are fine with Eibach sportlines.
No crazy driving these days, but been on the car three years now and drives like OEM.....sometimes a little harder with the springs, otherwise fine with the family
Mike
South Coast
Online pudding
  • -Receive: 692
« Reply #4 on: December 16, 2021, 10:40:20 am »
Haven't read anything bad about them personally, but I suspect negative feedback from those is from people thinking they're uprated (like the B6/B8), but they're not.  They are a like-for-like OEM replacement, perhaps 10% stiffer than stock at the most, as they're also designed to take mild lowering springs.
I've had the Racingline damper/spring kit in the past and I didn't like it.  A lot of other folk do though.
Offline Greeny
Re: Racingline shocks and H&R springs
« Reply #5 on: January 30, 2022, 05:12:15 pm »
Fitted up H&R lowering springs with the Racingline sport shocks. Will this take time to settle?
See the photos below. Comparing this to others with the H&R springs, theirs seems a lot lower than mine. I can only think that it's the shocks that might be causing it to sit higher currently, or is it my eyes and it is actually sitting correct?
Is anyone able to shed any light on it?
Cheers.
Offline ald1717
  • -Given: 17
  • My Ride: mk5 gti
« Reply #6 on: January 30, 2022, 09:45:29 pm »
thinking of replacing my dampers also and springs as the ones which are on seem very stiff and a tad too low as you sometimes get scraping on certain speedbumps, i have seen a bilstein b4 and eibach sportline kit for sale on ebay for £330 which seems good value, also considered the racing line but i think a member on here made the comment of being soft enough that there was some arch rubbing which put me off, i dont know if its just my car but its way too unsettled going fast over bumpy b roads,
Offline Bens313
« Reply #7 on: January 31, 2022, 09:27:14 am »
Which H&R springs did you get? Mines on the 30mm and sits a bit lower than yours. Your brand new shocks might give a bit more resitance causing it to sit higher. Did you make sure they are the GTI specific H&R springs not the generic MK5 ones some of the shops also sell?
« Last Edit: January 31, 2022, 09:29:03 am by Bens313 »
Online pudding
  • -Receive: 692
« Reply #8 on: January 31, 2022, 10:04:27 am »
It won't be the shocks causing it to sit high.  Suspect the springs are the non-GTI ones.
Offline Greeny
« Reply #9 on: January 31, 2022, 07:44:45 pm »
The springs I got are:
H&R KBA 91223
29176 - 1 VA front
29176 HA rear
Are these correct? I have just finished fitting them this weekend gone and driven it once for time reference to the photots.
Offline Bens313
« Reply #10 on: January 31, 2022, 08:20:28 pm »
Should be the correct ones at least acording to Awesome GTI. The ones i bought have the same part number as yours. Maybe it will settle a bit.
Offline Greeny
« Reply #11 on: January 31, 2022, 09:04:16 pm »
I think they are correct, I researched it a fair bit on the forums.
I just don't understand why it isn't as low as other cars with the same setup.
Offline Greeny
« Reply #12 on: February 01, 2022, 08:35:53 pm »
Anyone able to shed any light on why it's sitting higher that others?
Online pudding
  • -Receive: 692
« Reply #13 on: February 03, 2022, 01:08:03 pm »
Are you running spacers? Looks like it in the pics. If so then it will look different to cars without. Dunno what the big deal is anyway. Looks fine as it is.
Offline fazgti
  • Newbie
« Reply #14 on: February 03, 2022, 04:16:28 pm »
i have 12mm and 15mm spacers along with Bilsten B4s with 30mm H&Rs and mine is way lower then that.
