Author Topic: Shed clear out - Forum friendly pricing  (Read 13615 times)
  • -Receive: 692
« on: October 08, 2023, 02:10:36 pm »
Sold
Ohlins Road & Track Coilovers
£350.00
Single Image
    Postage: £15.00
    Delivery or Collection
    One of the fronts is knocking, so needs a rebuild - hence the price - otherwise all good.  They were working perfectly when I took them off, but were just noisy.  If someone wants to invest in rebuilding the front pair, these are superb coilovers. Excellent ride quality. Supplied in the -20mm position, which is spot on for fast road driving.
    All 4 still holding gas pressure, so the pistons return after being pressed in.  20 click adjustable damping and -10 to -40mm drop. Full kit that attaches to OEM top mounts. Spherical top mounts not required.
    Happy to meet half way if in reasonable distance of Suffolk and obviously drop the delivery fee.
    Sold
    MK7.5 Golf R/S3/Performance Pack/Cupra brake setup
    £150.00
    Single Image
      Postage: £15.00
      I bought these brand new some time ago.  OEM pads with tonnes of meat left. Bolt right on. OEM MK5 hoses can be used.  Braided lines not needed.
      The listing is for the calipers, carriers and pads only.
      If someone collects them, I will throw in the OEM Clubsport discs for free as they're getting close to the wear limit. I would say approx 10K miles left in them.
      Sold
      Vibratechnics dogbone mount - Fast Road spec - New unused
      £80.00
      Single Image
        Postage: £0.00
        Bought to replace a 6 year old one but never got around to it before selling the car.
        Sold
        GFB DV+
        £50.00
        Single Image
          Postage: £0.00
          Probably approx 10K use in total.  Genuine, no fakes on my watch!
          Sold
          OEM Red coils - bought from Audi, not online
          £50.00
          Single Image
            Postage: £0.00
            Due to the incessant fakery online, I bought these from an Audi dealer. Probably about 50K use in total. Still working perfectly.
            Sold
            OEM MAF
            £50.00
            Single Image
              Postage: £0.00
              Bought for troubleshooting but turned out to be something else, so hardly used. OEM bought from a VW dealer, not online.
              Sold
              S3 spec wishbone overhaul kit - Lemforder
              £100.00
              Single Image
                Postage: £10.00
                All the parts you need to refresh both ends of the wishbones to S3 spec (voidless bushes). Sold the car before getting a chance to fit them.
                I've done all the hard work for you in acquiring the correct bushings.  Also included is a pair of genuine Audi A2 console bushes, which is another voidless option you can try. The S3 bushes included are Febi as Audi don't sell the separately.
                Sold
                Equal length driveshaft kit
                £100.00
                Single Image
                  Postage: £15.00
                  Another project I never got around to trying.  Equal length driveshaft setup for the EA113 engine.  They are from a BKD diesel engine and the mounting points are on the EA113 block as standard, but for some reason VW never fitted it from the factory.  It's purpose is to kill torque steer.
                  The critical stub axle for the gearbox was bought new from VW (for £250 7 years ago!) and you can't get them anymore.  An interesting little summer project if someone fancies having a crack at it.
                  Sold
                  Eibach coilover springs - 450in/lb front, 425in/lb rear
                  £80.00
                  Single Image
                    Postage: £10.00
                    Bought to experiment with spring rates on the Ohlins coilovers. Hardly used. Might be some use to someone.
                    Sold
                    OEM cam chain timing tools
                    £50.00
                    Single Image
                      Postage: £10.00
                      The proper VW tools to do a cam chain replacement. Genuine cam locking tool and genuine inlet cam position adjustment tool.
                      Sold
                      Edition 30 engine ECU
                      £50.00
                      Single Image
                        Postage: £0.00
                        Standard ECU.  The original plan was to have 2 ECUs. One with a remap and one with a standard map, just to have as a backup and for troubleshooting.  Will need de-immobilising before it can be used. Plenty of ebay services can do that.
                        « Last Edit: October 21, 2023, 12:03:35 pm by Pudding »
                        Offline mk1_dave
                        Re: Shed clear out - Forum friendly pricing
                        « Reply #1 on: October 09, 2023, 07:15:15 pm »
                        Hi sent you a pm about some listings.
                        Offline FatWelshBoy
                        « Reply #2 on: October 09, 2023, 09:46:29 pm »
                        Hi, I've sent you a message.
                        Offline welikeaps
                        « Reply #3 on: October 14, 2023, 10:34:52 pm »
                        Too late as usual would of had those coilovers
