Author Topic: LED Number Plate Lights + LED Puddle Lights?  (Read 16430 times)
Offline S2 Ant
  • -Receive: 21
« on: April 18, 2010, 06:53:48 pm »
Hi All, has anyone done either of these?
I have some LED lights that i fit for the number plate bulbs and they turn on but then turn back off again and give a warning of the bulbs not working. I'm guessing its because they dont draw enough current to register and it thinks they've failed and turns off the power to them.
Has anyone fixed this in some way?
Also, has anyone tried replacing the puddle lights in the mirrors with LED's? I havent tried to yet in case i get the same thing happen with them as i am with the number plate replacement LED's but they deffo need doing as the normal bulbs look awful with the Xenon's on when turning the car off.
Any info appreciated :)
Ant
Offline DMcG
Re: LED Number Plate Lights + LED Puddle Lights?
« Reply #1 on: April 18, 2010, 06:56:41 pm »
You need to either add a resistor or purchase the ones with em already on so you dont get the bulb out light come on. Do a search on flea bay there are quite a few on there now. HIH
Offline S2 Ant
  • -Receive: 21
« Reply #2 on: April 18, 2010, 09:25:38 pm »
Ah ha, ok, i'll try find some resisted versions.
Next noob question, what type are they? I had some C5W's but they were a bit long compared to the standard bulbs, altho they fit, they stretched open the holder a bit much and wondered if there are some better fitting ones?
Ant
Offline v2brett
Still Here!
Offline S2 Ant
  • -Receive: 21
« Reply #4 on: April 18, 2010, 09:49:10 pm »
Ah yeh, forgot about that thread.
Does anyone know the type of bulb in the mirrors to save me pulling them apart to have a look? Hopefully its an easy access from underneath job or is it move involved?
Its dark out now and easier to pick peoples brains
Ant
Offline golfman
  • -Given: 17
« Reply #5 on: April 18, 2010, 09:53:41 pm »
I bought a set from ebay that i put into my puddle lights what a load of rubbish £25 for a set of bulbs that would only work sometimes :booty:
if anyone has bought some bulbs that will def work with the puddle lights and are the bright white colour with no bulb out warnings please do tell :wink:
cheers
scott
Vag-com Hex+Can in scotland
I Hate Timewasters...
Offline S2 Ant
  • -Receive: 21
« Reply #6 on: April 18, 2010, 10:11:11 pm »
Scott, how do you get to the bulbs in the mirrors? Do you have to take much apart to get at them?
I just had a quick look at the car expecting to find a small screw holding on the cover but it seems not.
Ant
Offline Howardvwgolf
« Reply #7 on: April 18, 2010, 11:34:10 pm »
iirc you fold the mirror back towards the front of the car and there is a screw holding the bulb unit in place, just take the screw out and pull that sucka out
Offline jabbalad
    • Jabbasport
« Reply #8 on: April 19, 2010, 12:33:45 pm »
i just got some normal cheap wedge led bulbs for my puddle lights (the same type as the sidelights), they have been in there since november and i havent had any trouble yet, there a nice white colour too  :smiley:
I will try and find what make they were tonight
12.7 santapod... soon to be quicker :-)
Candy White Edition 30; Custom KW clubsports, Eibach hollow arbs, Jabba remap, BTB Exhaust, Twintake, Autotech HPFP, Team Dynamics wheels, VWR Big Brakes.
Offline S2 Ant
  • -Receive: 21
« Reply #9 on: April 19, 2010, 01:30:05 pm »
Sounds good, thanks Jabbalad, then i can order both pairs at the same time :)
Ant
Offline S2 Ant
  • -Receive: 21
« Reply #10 on: April 19, 2010, 06:03:32 pm »
Right then, this is the bulb in my mirror puddle lights
What type is it please?
The housing says 13.5v and 6W on it for the rating i presume, there is writing on the bulb itself but its faded away and become unreadable
Ant
Offline 94Luke
« Reply #11 on: April 19, 2010, 06:16:10 pm »
Offline S2 Ant
  • -Receive: 21
« Reply #12 on: April 19, 2010, 06:21:19 pm »
Perfect thanks, that looks like the right thing, from looking at the faded print on the bulb i'd have said it was W6W but W5W looks possible too.
And finally one last question, do they need to be the type that shouldnt give an error or will the bog standard LED ones work?
« Last Edit: April 19, 2010, 06:23:07 pm by S2 Ant »
Ant
Offline bindinbear
  • Newbie lovin' the edition 30
« Reply #13 on: April 19, 2010, 06:53:04 pm »
I have checked with a vee dub specialist and apparently they are not monitored by the ecu. Having some fitted professionally to my Ed 30 on thurs and I will report back with a result. I did buy both types just incase. will also ask em to take some fitting photos :happy2:
08' Edition 30 no.1899. 5dr steel grey DSG. MFSW, xenons, sunroof, rns510, ipod prep, armrest, voice activation, bluetooth, parking sensors.
Offline S2 Ant
  • -Receive: 21
« Reply #14 on: April 19, 2010, 06:57:12 pm »
Coolio, i'll hold off til then, fitting them should be a 5 min job for both.
I did wonder if the ECU would monitor them or not given they only operate once the car is turned off so you wont be in the car to get a warning lol
Once you report back i can order the right ones
Ant
