Author Topic: NQS BBK A Not Quite So Big Brake Kit..NQS Rear mods now.....  (Read 548722 times)
Offline tony_danza
  • -Receive: 112
Re: NQS BBK A Not Quite So Big Brake Kit..With Install Pics
« Reply #420 on: November 14, 2011, 04:53:52 pm »
Grooved/Js don't do much for cooling - more for pad sweeping... which isn't much cop when they're munching the pads on the motorway.
That said, ATE powerdiscs are cheapish and very good, never seen one crack.  :happy2:
Sideways yo!
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #421 on: November 14, 2011, 05:16:20 pm »
Right, Tony. Ate PowerDisc offer great value for money.
I'm sure the Tarox' are even better though.
It doesn't make a huge difference if you decide for Zero,
SJ, G88 or F2000. They are all heat treated and made
from the same casting.
Mike, remember all grooved discs will cause some noise
(hum) when decelerating from high speed.
"You get what you pay for."
« Reply #422 on: November 14, 2011, 05:59:42 pm »
Noise doesn't bother me I just want a good balance between discs that won't eat my pads if used daily and something that will perform on the odd track day.
I should get some more oem Porsche  textar pads and oem gti discs for street and save the pagid for track days with some Tarox discs :)
« Last Edit: November 14, 2011, 06:22:10 pm by Tfsi_Mike »
Offline tony_danza
  • -Receive: 112
« Reply #423 on: November 14, 2011, 09:00:57 pm »
I've had G88s on the old MKIV, they do indeed take some hammering - they used to race through pads though. I guess you have to just balance for your needs.
Sideways yo!
« Reply #424 on: November 14, 2011, 09:23:23 pm »
In had g88 and tarox strada pads on my old car and I would say the wear was almost like OEM stuff. Maybe the Tarox pads are slightly harder compound?
Offline jimk04
« Reply #425 on: November 15, 2011, 07:14:06 am »
Why are the plentiful front 996 model calipers not advised for this conversion. They look identical to the 987 ones but are easier to come by?
Milltek tbe, Forge intercooler, AMD map, Eibach Sportlines, Porsche 996 over AMG 330mm homegrown BBK
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #426 on: November 15, 2011, 09:46:55 am »
996 Caliper is wider, same piston sizes as the boxster caliper. The disc thickness is also 28mm and there not a suitable disc from VAG that suits.
That said I've used the 996 caliper on the mk4 on another disc (330mm) and also on the 6r polo
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #427 on: November 15, 2011, 02:04:20 pm »
Boxster calipers are rel. cheap even when purchased new from Porsche.
I rate the NQSBBK as the very best value of all brake conversions.
Guess there are even two piece discs from Tarox and AP for an upgrade
later if you feel a need.
The only downside is ''TÜV'' in Germany. It's always the same . . .   :jumping:
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #428 on: November 15, 2011, 04:01:52 pm »
Tarox are making 2 piece 312x25 (G88, F2000, etc) discs but they are 600 EURO/pair. Quite expensive if you ask me...
« Reply #429 on: November 15, 2011, 04:03:00 pm »
What would you reckon their life expectancy like with fast road with a few track days in the summer?
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #430 on: November 15, 2011, 04:30:19 pm »
I can only guess... But my guess is that they should be good for 2+ years. I am thinking they should be similar with my J hooks that have 1 year with some track days with minimal wear.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #431 on: November 15, 2011, 05:59:35 pm »
just out of interest Mike did you go from the OEM 345mm to the 312mm NQS? how did they compare?
PLANS: Stage 2+
« Reply #432 on: November 15, 2011, 06:03:09 pm »
I posted somewhere on this thread.
The improvement in handling was great due to the weight saved.
Now they're well bedded in they're brilliant :)
I can't wait to upgrade discs / pads and fluid soon :( will report the difference.
Offline mortygttdi
  • -Receive: 146
« Reply #433 on: November 15, 2011, 06:12:19 pm »
I just need my fitting kit so I can feel the difference :happy2:
I think Dave is silly busy and I don't like to pester him so ill wait till he get to me, I'm in rush this side of xmas now.
Darren
Offline jedi-knight83
  • -Receive: 41
« Reply #434 on: November 15, 2011, 06:22:06 pm »
A friend of mine is selling some 996 calipers...
996-351-425 | 426
I gather these ar from a boxster S.
Will these not fit?
