Author Topic: NQS BBK A Not Quite So Big Brake Kit..NQS Rear mods now.....  (Read 556568 times)
Re: NQS BBK A Not Quite So Big Brake Kit..NQS Rear mods now.....
« Reply #795 on: March 27, 2013, 12:14:18 pm »
^^^^ that will be VERY close with 8" ET50. Mine are 8" ET44 and has some room to spare, maybe 7mm max without spacers. I'd get spacers if I were you.
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #796 on: March 27, 2013, 01:06:50 pm »
It is not a question of offset (ET)! I have 17inch BBS rims with ET 50 and I have about 7-8mm of clearance (without spacers!).
It depends on each rim individually....
Offline Kalpsn2000
  • -Receive: 56
« Reply #797 on: March 27, 2013, 01:49:00 pm »
It does but offset also comes in to it.
I don't have a close-up but this is mine with 12mm spacers and Monza II's:
« Last Edit: March 27, 2013, 01:51:22 pm by Kalpsn2000 »
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #798 on: March 27, 2013, 02:20:18 pm »
Offset says nothing about the rim clearance, unfortunately...
Of course the lower the ET the lower the chances of having clearance issues but that does not help. There are rims with the same offsetthat have 2cm of clearance, or 7mm of clearance or have negative clearance. So, my advice is: ET should not be taken into account. The best way is to measure the clearance (like I said above) to have an estimation...
Offline Ess_Three
« Reply #799 on: March 27, 2013, 10:26:51 pm »
Fair enough...thanks.
I can't remember there being an awful lot of room left when lowered 25mm and using 8" x 18" ET50 CHs.
If you don't scrub with ET44s, there must be at least 6mm...so 8mm *should* be OK.
I'm still using a 225 wide tyre...so fingers crossed.
I guess I'm going to have to do some measuring and sort out some spacers.
Offline stubert
« Reply #800 on: April 27, 2013, 01:38:12 pm »
Could someone help me with the anti rattle shims?
Is this the correct one to buy ( x 4 )?
Top left - http://porschecalipers.co.uk/uk/81/products_categories/9/anti_rattle_shims.html
« Last Edit: April 27, 2013, 01:39:49 pm by stubert »
« Reply #801 on: April 27, 2013, 01:46:31 pm »
You need these ones (below), expensive from eurocarparts.com as you'll need 4, half the price from your local Porsche Centre.
eurocarparts.com.......
~~ Clicky here ~~
Offline stubert
« Reply #802 on: April 27, 2013, 01:51:18 pm »
Thanks.  I'd been looking on ECP but couldn't find them.  "Priced per axle" but it also says "Quantity required - 4".  Any more info on this?
Are they not the same as the ones I posted and also these - http://www.design911.co.uk/fu/pt66_209_-cma81-cmo82/Porsche/Boxster-986-987-981/Brake-Pad-Anti-vibration-shims/ ?
« Reply #803 on: April 27, 2013, 02:07:17 pm »
^^^^ they're £80 from eurocarparts.com as you'll need 4 even though it says per axel.  :stupid:
I've no idea on the other ones, they do look exactly the same. I just went to Porsche and asked them.   :ashamed:
Offline stubert
« Reply #804 on: April 27, 2013, 02:19:52 pm »
Thank you.
ECP will be cheapest when I take 25% discount into consideration.
Offline Biano44
  • The CC GT 200
« Reply #805 on: May 13, 2013, 02:01:27 pm »
Hi Guys,
So I set up a mock up of my new Merc rims (18x8 ET44) my new 312 cross drilled discs and my Porsche calipers and to my horror I only have 3-4mm clearance due to the design of the rim.
My question is, what size gap do I need to be safe?
Ta.
Offline AndyED30
  • ED30
« Reply #806 on: May 14, 2013, 11:04:28 pm »
You'll be 'safe' with that no doubt.
If you wanted a little more then get some small spacers.
Offline jimk04
« Reply #807 on: May 15, 2013, 07:14:51 pm »
4mm....loads of room! :happy2:
Milltek tbe, Forge intercooler, AMD map, Eibach Sportlines, Porsche 996 over AMG 330mm homegrown BBK
Offline deebow
« Reply #808 on: May 19, 2013, 01:41:22 pm »
hi
 looking to upgrade my eos to this bbk. now ive managed to get a set of boxster brakes was wondering in regards to cleaning them up whats the best cleaner to use to get them clean so I can see what the general condition is like?
Offline bacillus
  • -Receive: 453
« Reply #809 on: May 19, 2013, 04:11:30 pm »
hi
A soapy solution of fairy liquid will do wonders...
