Author Topic: cd player FINALLY FITTED what you think??  (Read 14732 times)
Offline jaffa666
« on: June 29, 2010, 09:55:11 pm »
EVENTUALLY got this in and workin as it should, after about a million attempts.
thanks to GTI_MAD and anyone else who tried to guide me in the right direction, I have fitted loads of sound systems, and handsfree kits to other cars I have owned, and never had as much trouble.
Turned out the ignition wire I had ran, had a break in it, if i had a multimeter i could have tested this but being a new wire i couldnt see that being the problem, after loads of different plug swapping etc, i decided to run a new wire and hey presto.
« Last Edit: July 03, 2010, 12:45:57 pm by jaffa666 »
Offline Gti_Mad
Re: Help needed fitting new cd player
« Reply #1 on: June 29, 2010, 10:02:09 pm »
is the wire from the fuse board live all the time or just with the ignition ???
Offline Alexander
« Reply #2 on: June 29, 2010, 10:18:17 pm »
Since you have what could possibly be the nicest headunit on the forum I demand pics when its fitted! :signLOL:
2005 Black Audi A3 Sportback TDI-Bose and Full Leather
2005 Black 3Dr GTI-Leather and Upgraded Sound System-Gone
Offline jaffa666
« Reply #3 on: June 29, 2010, 10:22:06 pm »
Not sure mate, I havent tapped into the fuse box yet, as i couldnt mind what one I used for the parrot handsfree kit.
if i connect the red wire from the back of the headunit to the red wire coming from the wiring adaptor I have to turn the headunit on and off manually, and it doesnt matter if the ignition is on or not.
dunno if this helps you any.
Offline jaffa666
« Reply #4 on: June 29, 2010, 10:22:50 pm »
Will do mate, lol, will be selling the thing before long if I cant get it working right,  :signLOL:
Offline Gti_Mad
« Reply #5 on: June 29, 2010, 10:26:23 pm »
were u based bud??
Offline jaffa666
« Reply #6 on: June 29, 2010, 11:14:40 pm »
Falkirk in central scotland you coming to help me, lol
Offline jaffa666
« Reply #7 on: June 30, 2010, 08:21:55 am »
Can anyone help me out with this, was hoping to get this sorted today.
Offline Gti Jal
« Reply #8 on: June 30, 2010, 06:40:51 pm »
Jaffa,
Not sure how much you know and some of this may be teaching you to suck eggs.
1. The usual practice is permanent live and switched live. Most Radio's allow you to turn it on with just permanent Live.
2. This how to guide tells you exactly how to add a switched live http://www.golfmkv.com/forums/showthread.php?t=62584 You need a repair wire available from the dealer.
3. You may find it easier to find a switched live off the back of the fag lighter. Avoid scotchloks they are crap.
Hope this helps.
Offline jaffa666
« Reply #9 on: June 30, 2010, 09:35:14 pm »
How do I get into the back of the fag lighter?
Offline Gti_Mad
« Reply #10 on: June 30, 2010, 09:38:51 pm »
pull the gear lever up and there's a couple of torx screws as far as im aware bud
Offline micaerin
  • -Given: 19
« Reply #11 on: June 30, 2010, 09:54:39 pm »
That 20amp fuse is for your headlamp washers as mine was blown changed and hey presto headlamp washers worked :happy2:
2007 GTI DSG, Xenon's, Armrest 6 Disc ,Rear Parking Sensors,Sunroof,Lux Pack,Cruise,Electric drivers seat,MFSW,RNS 510,Miltek Cat Back.
Offline jaffa666
« Reply #12 on: June 30, 2010, 10:44:57 pm »
Top bloke, never even knew I had them,  :signLOL: :ashamed:
will swap that fuse and have a scoosh.  :happy2:
Offline jaffa666
« Reply #13 on: July 01, 2010, 09:03:52 pm »
I have found out that I got the ignition life from for the parrot handsfree sticking a spade connector in the empty fuse slot with the dodgy looking arrow pointing to it.
so  my question is where do i connect the ignition wire that I have ran, to the back of the head unit?
« Last Edit: July 01, 2010, 09:07:56 pm by jaffa666 »
Offline Gti_Mad
« Reply #14 on: July 01, 2010, 09:07:21 pm »
it will be iver the red or yellow wire in the adapter plug you have fitted with bullets...... 1 will be for the ignition the over is for a permanent live
