Author Topic: Finally got a chance to finish the mapping on my car... dyno results  (Read 6535 times)
Offline PDT
  • -Receive: 142
On sunday I finally got a chance to finish setting up the ED30 with some road datalogging and dyno testing we ended up with:
Boost:8
Timing:8
Fuel:5
Mods are:
Milltek full turboback 3" decat resonated system
Dbilas/pipercross DIY intake
Autotech fuel pump
DSG stage 2 REVO
Forge Twintercooler
REVO stage 2+ software
(photo missed the dyno calculations at the bottom which were: Intake temp: 37 ambient temp 23 Barometric pressure 1013 humidity 45)
The addition of the twintercooler allowed us to take timing from 5 to 8 which took the car from 357bhp to the figure you see above, however torque has dropped from 380 ft/lb as we had to lower boost from 9 to 8
Offline cuprak1
  • Cupra k1 - 360 bhp/360 ft-lbs
    • London web design
Re: Finally got a chance to finish the mapping on my car... dyno results
« Reply #1 on: July 20, 2010, 04:22:32 pm »
Looking good mate :)  :congrats:
SpeedStats iPhone app  - AVAILABLE NOW!
View my Cupra k1 project thread here! 360is
« Reply #2 on: July 20, 2010, 05:13:55 pm »
Looking good Dave :happy2:
Offline Janner_Sy
  • -Receive: 113
« Reply #3 on: July 20, 2010, 05:52:51 pm »
awesome figures for DD rollers. How come the curves are so condensed, is it possible to spread them over the complete width of the graph, its better to compare the curves with others then.
the new dyno graph thread here as well :happy2:
http://www.mk5golfgti.co.uk/forum/index.php/topic,16977.0.html
would look better if you could get the torque an power figures on each side of the graph the same
« Last Edit: July 20, 2010, 06:07:08 pm by vRSy »
« Reply #4 on: July 20, 2010, 05:58:18 pm »
Timing 8 OMG, were you on normal 99 ron or race fuel?
Did you get any logs done?
Good result on the run :happy2:
Offline PDT
  • -Receive: 142
« Reply #5 on: July 21, 2010, 12:24:25 pm »
I can adjust the scale of the graph but this is how we set up the screen for all dyno tests.
Hurdy, this was using 'normal' 99 octane fuel, the twintercooler really helps keep intake temps really low, we saw a timing pull figure of 4 degress after a few 4th gear pulls but intake temps were still at just 34 degrees.  On the dyno this raised to 5 degrees of pull and an intake temp of 43 degrees after 3 dyno pulls at WOT.
Offline Janner_Sy
  • -Receive: 113
« Reply #6 on: July 21, 2010, 05:04:49 pm »
:happy2: :happy2:
throw it in the new dyno thread :happy2:
Offline bacillus
  • -Receive: 453
« Reply #7 on: July 21, 2010, 05:35:33 pm »
The rpm scale is not shown so could you state @what rpm do you see your max hp at.
Offline Tara
« Reply #8 on: July 21, 2010, 06:08:27 pm »
Looking good! :happy2:
Offline theo
« Reply #9 on: July 21, 2010, 06:12:05 pm »
Interesting results dave. Looking forward to getting mine dyno'd now and seeing what results it gives!
Offline Sunglasses Ron
« Reply #10 on: July 21, 2010, 06:19:48 pm »
Awesome results mate. Looking forward to seeing what mine will make on DD rollers on Sat (same mods, just without the the cooler and standard Dbilas). Although it aint going to be as high as that even though I have the same mods, just without the the cooler and standard Dbilas (not hybrid).
I will however be running early in the morning so that should help as the temps on sat according to the weather should only top 18oC. Just unsure what settings to run, as I don't have VAGCOM  :sad1:
Any ideas?
Offline Poppa Dom
« Reply #11 on: July 21, 2010, 07:05:19 pm »
Are you stage 2+ Ben? Go for b8t5f6 if you are as a baseline.
« Reply #12 on: July 21, 2010, 07:08:18 pm »
That's exactly what I am at the min mate and seems pretty good. Just don't boot it much when it gets silly hot outside (like 25+ on temp gauge).
Offline gazbutS3
« Reply #13 on: July 21, 2010, 07:47:02 pm »
I'm running that also B8 T5 F6, and have logged it and its all pretty good as shown by the results at the Halifax RR day :happy2:
Offline Janner_Sy
  • -Receive: 113
« Reply #14 on: July 21, 2010, 07:49:04 pm »
gaz, post your graph up in that thread, and then if PDT can change the scales on his graph we could make a good comparison between the two.  iirc yours was similar at the last RR day??
