Author Topic: BEWARE YOU DV VALVE COULD LOOK LIKE THIS!!  (Read 26674 times)
Offline oly2k2
  • Albion Till We Die!!
« on: August 19, 2010, 04:51:01 pm »
Hi All, after reading all the info on this site regarding DV Valves i decided to change mine to the OEM version D, as i own an 05 GTI, and it is recommended that on models this early it be replaced,
I am very pleased i decided to change mine as my car now feels a whole lot better and is alot faster, and would recommend anyone with an early MK5 GTI to replace their DV valve for the latest version,
Reason for my post is that i have uploaded some pics of my DV Valve and it shows just what condition yours could be in too.
Andy
« Last Edit: August 19, 2010, 05:15:04 pm by oly2k2 »
Offline gazbutS3
Re: BEWARE YOU DV VALVE COULD LOOK LIKE THIS!!
« Reply #1 on: August 19, 2010, 04:53:07 pm »
that is fubbared
I took one out of my mates 56plate GTI the other day and that was in a sorry state as well, not quite that bad though :laugh:
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #2 on: August 19, 2010, 05:02:23 pm »
Would you say you noticed the car was 'off' before you changed it?  Did still pull strongly / ie you could feel the turbo kicking in?
Sepang Blue S4 BE Avant
Offline SeanyK
  • -Given: 35
« Reply #3 on: August 19, 2010, 05:04:53 pm »
Nasty stuff, I have an early 2005 model so will order in the D version DV just as a matter of precaution.
Offline oly2k2
« Reply #4 on: August 19, 2010, 05:11:22 pm »
Hi there, yes i noticed the car was off so to speak, it was very slugglish, and the turbo seemed to kick in very late, there ws also this hissing sound when putting you foot down, after changing the DV the car is now alot faster, accleration is alot more solid, and the turbo kicks in alot earlier.
the last pic shows the box and part number of the replacement Version D valve
gaz b
« Reply #5 on: August 19, 2010, 05:29:35 pm »
I was actually just going to post the exact symptoms that you have satated! :surprised:
A faint hissing when you accelerate and certainly no grunt. :sick:
Is it easy to check the DV valve, where is it and how much is a new one? Mines is also an 05.  :drinking:
Offline keano
  • -Given: 79
« Reply #6 on: August 19, 2010, 05:33:46 pm »
Do the edition 30's have the revised DV?
Or is it worth swapping mine?
Offline oly2k2
« Reply #7 on: August 19, 2010, 05:39:04 pm »
its located under the driver side wing, u have to remove the wheel and then the wing liner, its directley behind there, 3 x 7mm(i think) allen key bolts hold it in which are a bit fiddeley but with a bit of patience they will come out, when refitting i would recommend you use some thread lock when replacing the allen bolts, cost was £47.00
gaz b
« Reply #8 on: August 19, 2010, 05:41:24 pm »
You are a gentleman!  :happy2:
Offline matsu
  • -Given: 78
« Reply #9 on: August 19, 2010, 06:06:39 pm »
my car, an 05 def has this but no hissing i,m aware of.
so i,m def having this done.
if mine looks bad ill post pics up too.
matsu
Offline no golf clubs at all
« Reply #10 on: August 19, 2010, 06:11:38 pm »
I haven't noticed sluggishness but like boiling a frog Perhaps the effect is gradual and you don't realise over time....I'm going to look into this too..I get the hissing sound. Sept 05 build my06.
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #11 on: August 19, 2010, 06:18:52 pm »
I take it the pic of the part box is the correct part number ?. :happy2:
Offline Ross_46
« Reply #12 on: August 19, 2010, 07:12:53 pm »
might be a daft question but i have a 57 plate done 22k. would that have the new version or should i get it changed as a precaution???
57 Plate, Black, Monza 18's, Ipod armrest, Cruise, Revision D DV, Forge Twintake, Milltek non res, Revo Stage 1
Offline bacillus
  • -Receive: 453
« Reply #13 on: August 19, 2010, 07:18:29 pm »
I very much doubt you will have the D version unless it was changed without your knowledge.
Offline Ands GTi
« Reply #14 on: August 19, 2010, 09:02:44 pm »
When did the D version come into production? I have a 2006 (06 plate). Bit worried after seeing that!  :surprised:
Also why is the D version better over going with an aftermarket one e.g Forge?
« Last Edit: August 19, 2010, 09:07:15 pm by Ands GTi »
MK5 (06) GTI; Previous: (57) Audi A3 TDI & (05) Seat Leon Cupra R 225 & (51) Seat Ibiza Cupra 1.8 20VT
