September 02, 2026, 01:40:06 am
All Things Mk5
How to Guides / Troubleshooting
fuel filter
Topic: fuel filter (Read 3640 times)
jimmy-s3
Won't Shut up.
-Given: 1
-Receive: 7
fuel filter
August 22, 2010, 02:18:46 pm »
How do you release the pipe connectors from the fuel filter? Is there a special trick??
rotty80
Taking part
-Given: 0
-Receive: 0
Re: fuel filter
Reply #1 on:
August 22, 2010, 05:10:00 pm »
You just press the clips in and then pull the pipes off.
jimmy-s3
Won't Shut up.
-Given: 1
-Receive: 7
Re: fuel filter
Reply #2 on:
August 22, 2010, 05:35:54 pm »
Thanks rotty80!!!
s4lek
Always Involved
-Given: 18
-Receive: 1
Re: fuel filter
Reply #3 on:
August 25, 2010, 12:26:31 am »
hi jimmy, could you tell me if the filter is in the same place for the gti and where abouts it is, and how much it cost you
SeanyK
Always Involved
-Given: 35
-Receive: 14
Re: fuel filter
Reply #4 on:
August 25, 2010, 07:48:42 pm »
Just in front of the rear drivers side wheel.
From memory it costs about £19 for a fuel filter.
s4lek
Always Involved
-Given: 18
-Receive: 1
Re: fuel filter
Reply #5 on:
August 26, 2010, 10:10:54 am »
Cheers.
bodger00
Won't Shut up.
-Given: 23
-Receive: 20
A wish called Zonda
Re: fuel filter
Reply #6 on:
September 02, 2010, 09:28:39 pm »
When is this recommended to be changed as per standard servicing? Anyone know?
bacillus
Just look at my post count
-Given: 4
-Receive: 453
Re: fuel filter
Reply #7 on:
September 02, 2010, 11:43:09 pm »
Recommended to be replaced every 40k miles...
bodger00
Won't Shut up.
-Given: 23
-Receive: 20
A wish called Zonda
Re: fuel filter
Reply #8 on:
September 04, 2010, 10:34:56 am »
Really? 40K? It looks easy to get off but whats the process? Is there a valve to stop the contents of the tank draining all over the floor?
xxx_mojo_xxx
-Given: 39
-Receive: 19
MUBster DUBster
Re: fuel filter
Reply #9 on:
September 04, 2010, 10:51:19 am »
All Things Mk5
fuel filter
