Author Topic: fuel filter  (Read 3636 times)
Offline jimmy-s3
fuel filter
« on: August 22, 2010, 02:18:46 pm »
How do you release the pipe connectors from the fuel filter? Is there a special trick??
Offline rotty80
Re: fuel filter
« Reply #1 on: August 22, 2010, 05:10:00 pm »
You just press the clips in and then pull the pipes off.
Offline jimmy-s3
Re: fuel filter
« Reply #2 on: August 22, 2010, 05:35:54 pm »
Thanks rotty80!!!
Offline s4lek
  • -Given: 18
Re: fuel filter
« Reply #3 on: August 25, 2010, 12:26:31 am »
hi jimmy, could you tell me if the filter is in the same place for the gti and where abouts it is, and how much it cost you
Offline SeanyK
  • -Given: 35
Re: fuel filter
« Reply #4 on: August 25, 2010, 07:48:42 pm »
Just in front of the rear drivers side wheel.
From memory it costs about £19 for a fuel filter.
Offline s4lek
  • -Given: 18
Re: fuel filter
« Reply #5 on: August 26, 2010, 10:10:54 am »
Cheers.
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
Re: fuel filter
« Reply #6 on: September 02, 2010, 09:28:39 pm »
When is this recommended to be changed as per standard servicing? Anyone know?
Offline bacillus
  • -Receive: 453
Re: fuel filter
« Reply #7 on: September 02, 2010, 11:43:09 pm »
Recommended to be replaced every 40k miles...
Offline bodger00
  • -Receive: 20
Re: fuel filter
« Reply #8 on: September 04, 2010, 10:34:56 am »
Really? 40K? It looks easy to get off but whats the process? Is there a valve to stop the contents of the tank draining all over the floor?
Offline xxx_mojo_xxx
  • MUBster DUBster
Re: fuel filter
« Reply #9 on: September 04, 2010, 10:51:19 am »
 :popcornsoda:
