Author Topic: R32 brake refurbishment  (Read 6120 times)
Offline evvo
    • Moshi Monsters Cheat Codes
« on: January 27, 2011, 03:20:36 pm »
Anyone know were i can get my R32 brakes refurbished? They need stripping powder coating and rebuilding.
Any advice greatly appreciated :)
Chris
Completly standard 1977 Miami Blue MK1 Polo N 27500 miles one owner from new!
Offline markymark
Re: R32 brake refurbishment
« Reply #1 on: January 27, 2011, 03:21:45 pm »
Chris
Just give them to me, you dont need them on that dirty old soot chucker! :P
Offline evvo
« Reply #2 on: January 27, 2011, 03:25:53 pm »
 :P get your own :P there to go behind these
Offline markymark
« Reply #3 on: January 27, 2011, 03:26:36 pm »
You tart! :booty:
Offline evvo
« Reply #4 on: January 27, 2011, 03:29:38 pm »
 :star: :happy2:
Offline markymark
« Reply #5 on: January 27, 2011, 03:35:17 pm »
DaveB is the resident brake guru, might be worth asking him where is best to send them.  :happy2:
Offline evvo
« Reply #6 on: January 27, 2011, 03:39:55 pm »
cheers Mark i'll drop him a pm tonight :)
Chris
Offline swf7y
« Reply #7 on: January 27, 2011, 03:57:36 pm »
Alloys look fab  :drool: What are they?
Offline evvo
« Reply #8 on: January 27, 2011, 04:12:48 pm »
the 19" x 9" ET41 Audi A8 BBS splits I've had them split and powder coated black :)
Offline swf7y
« Reply #9 on: January 27, 2011, 05:50:08 pm »
They do look nice.  :happy2: Will they not scrub with that offset and width?
Offline evvo
« Reply #10 on: January 27, 2011, 07:22:16 pm »
No mate there the same setup as bentley rims. I'm going to be running 215 35 19 tyre and I'm lowered on kw v3's
Offline SteveyD
« Reply #11 on: January 27, 2011, 09:50:00 pm »
Hi,
Where are you based? I refurbed my own R32 calipers they are pretty easy to do.  Split them in half by removing the 4 bolts, you can clean the aluminium block and piston by hand and with mild cleaners.
I had a friend shot blast the blue section with fine blast, i then cleaned with alcohol based panel wipe and handed them over to the powder coaters, the colour looked almost day glow pink but once baked they turned out a lovely signal red.  Most powder coaters will also shot blast and the total job wont cost the earth if you do the prep work i.e splitting them.
Rebuilding is slightly harder, you need a vice and something to prevent marking i.e softwood block, the trick is to secure the painted section and bolt the alu caliper back on, a good pinch with a breaker bar is enough torque to hold them together, you dont want to strip the threads.
dont forget new stretch bolts for mounting them to the car.  simples  :happy2:
« Reply #12 on: January 27, 2011, 10:44:55 pm »
i have got some r32 calipers to put on mine next week..mine had been refurbed already
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #13 on: January 27, 2011, 11:20:41 pm »
Not wanting to burst any bubbles but that pic just looks like the whole caliper has been painted, the pad gallerys in the carriers should be blasted and etch primed and masked off to give good operation without corrosion.
I would say if you are going to split your own calipers then ANY machined surface needs masking up - just like OEM.
I would be also suspicious of any piston housing thats been sat at 180-200 degrees in the powder coaters oven for 20-30 mins.
Thats a dry prolonged heat, on a fairly skinny rubber seal thats designed to get hot but whilst immersed in oil, indeed prior to fitting the seals should be immersed in a wetting agent prior to fitting and then reassembled with lithium grease.
You cant really say "well it should be ok" when it comes to brakes....
« Reply #14 on: January 27, 2011, 11:24:14 pm »
Dave you have a PM buddy!
