Author Topic: R32 Clocks  (Read 2786 times)
Offline Johnny_tro
R32 Clocks
« on: March 25, 2011, 03:49:02 pm »
Hi all, have a 2004 GT TDI.......that all i know. lol I have the standard clocks, but want to replace them for the one pictured below.....
How do I tell if these will work in my car?
'VANDALISED' MK5 GT :( - RNS510 H, Bluetooth Armrest, MDI, 50gb hard drive, I can't park  sensors, Cruise Control, Highline Display, MFSW, Heated Seats, Remote Aux Heating System (Heats and Vents) Winter Pack, Heated & Folding Mirrors, Puddle Lights, Xenons, Headlamp Washers, Heated Washers, Auto lights and wipers, LED's, GTI brakes,, black R32 roof lining, Scirocco Rear View, Rear Footwell Lights
Offline Richn83
  • -Given: 49
  • -Receive: 86
Re: R32 Clocks
« Reply #1 on: March 25, 2011, 03:57:10 pm »
AS a rule of thumb you normally that your cluster part number which for a mid line will finsih 96x with your car I think x will be 1 or 2 you then find clocks that end 97x which is the highline version.  It is obviously a bit different when moving from a TDI to GTI clocks so Im not sure if this logic will follow.
But the pic of the clocks youve shown are already fitted in a TDI and an early one like yours I believe so it should be fine, but you will need somone with vag commander to do the coding switch.  Also worth checking where the current owner had the clocks coded and what age they are as the immobiliser were changed in 2006 to a harder encryption type.
Offline Johnny_tro
Re: R32 Clocks
« Reply #2 on: March 25, 2011, 04:53:02 pm »
OK, soooo
"immobiliser were changed in 2006 to a harder encryption type" does this mean it makes the VAG coding harder or impossible to do?
and where/how can I check the part number/code on my clocks?
Offline Richn83
  • -Given: 49
  • -Receive: 86
Re: R32 Clocks
« Reply #3 on: March 25, 2011, 05:08:19 pm »
it means you need proper VAG registered tools to get the access code from a server in Germany or so im lead to believe, which means Shark performance hazydays or a VAG dealer with VAS to code them.
to find your part number you need a vcds scan or you could take your clocks out and see if the label with the part number is intact on the rear.  I would guess the R32 clocks are probably post 2006 as they have been retro fitted but the seller should be able to tell you all those details.
Offline apollo13
  • -Receive: 47
Re: R32 Clocks
« Reply #4 on: March 25, 2011, 05:14:56 pm »
Johnny, Rich is spot on  :happy2:
Those clocks have already been retrofitted into an early TDI so should be the early immo type. Just check with Ollie to be sure. As long as the part number ends in 970,971 or 972 then your fine. Although I don't think R32 clusters where older than 972.
All you will need is someone with VAG K+CAN Commander to do the swap. Darren (Morty),EddieNL and I have all got it , just depends on where you are.
The swap is easy and takes 5 mins  :happy2:
Offline mortygttdi
  • -Receive: 146
Re: R32 Clocks
« Reply #5 on: March 26, 2011, 06:31:45 am »
Yeh if thats ollies set of clocks then he actually has a 1.6 petrol and I fitted the clocks for him so know they will go straight into an early car :happy2:
Darren
