Author Topic: Fitting a Revision D Diverter Valve  (Read 1708 times)
Offline swiftlupogti
« on: April 29, 2011, 02:17:11 pm »
is there a 'how to' thread on here anywhere?
cant find one on the search.
thanks
Re: Fitting a Revision D Diverter Valve
« Reply #1 on: April 29, 2011, 02:18:47 pm »
K03 or K04?
« Reply #2 on: April 29, 2011, 03:12:43 pm »
K03!
Offline vRS_Pagey
  • -Receive: 59
« Reply #3 on: April 29, 2011, 03:17:52 pm »
Have you tried a search, there are loads of threads on fitting mate which will be more concise but:
It's fairly straight forward, get the front up on axle stands, drop the engine tray.  Go under from the front and follow the down pipe up to the turbo, the DV is bolted on the side, carefully unplug the electric cable, then its 3 x T25 bolts iirc, take it off and replace.  Refit in reverse.   :happy2:
