Author Topic: What did you and your MKV do today?  (Read 4006350 times)
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #10185 on: February 28, 2017, 05:09:12 pm »
I bother with torquing the wheel bolts to spec: 120 Nm (~90 lbft). I've read about it online and agree with what the experts said: just apply anti-seize grease between the hub and wheel and torque the bolts to spec on the correct order.
I remove my wheels often enough so I don't expect to have any problems with corrosion. And the weather here also helps... :laugh:
Offline OEM+ DUB
« Reply #10186 on: February 28, 2017, 05:47:14 pm »
+1 for copper anti seize on mounting face and bolt threads - used it since I started driving (long time ago now) and always torque the bolts to 120nm when refitting after removal.
OEM+ 2005 GTI DSG (high factory standard spec and upgraded with S3 alloy hubs, S3 alloy wishbones, Bilstein B8s and VWR springs by my own hands) owned since 2008 and still loving it!
« Reply #10187 on: February 28, 2017, 05:56:25 pm »
I wouldnt use copper grease on anything, makes a right mess.
Aluminium anti sieze is much cleaner to use. Using that on bolts would be ok... but I wouldnt use actual "grease" on them.
Offline grey golfster
  • -Given: 79
« Reply #10188 on: February 28, 2017, 06:25:25 pm »
I bother with torquing the wheel bolts to spec: 120 Nm (~90 lbft). I've read about it online and agree with what the experts said: just apply copper grease between the hub and wheel and torque the bolts to spec on the correct order.
Mmmmmm.....so that's a steell hub + alloy wheel, connected by steel bolts, all clagged in coper grease...and heated...and wet...And you don't think there will be any problems with corrosion?
I use Ceratec ceramic based brake grease to keep the wheel from sticking to the hub. Non-metallic, so not galvanic. Not expensive.
Not so sure about greasing whel bolts tho?
Fairly sure thay are specd as a dry torque? I'm sure Someone on here will be able to quote VW on this?
I really can't imagine VW providing a torque wrench for this job. You're lucky to get a spare wheel on many of their cars!
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #10189 on: February 28, 2017, 06:39:21 pm »
You're right. It wasn't copper grease that I read but anti-seize. I haven't applied any anti-seize so far to be honest because I haven't bought any but I've seen some mechanics apply it. Thanks for the correction. :smiley:
Offline Newbieintown
« Reply #10190 on: February 28, 2017, 09:05:08 pm »
TPS IN EXETER ARE sh*te won't sell to the public!!!
@dools225
Hi mate no I got the switches off ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=232232538652#ht_1223wt_1222
Handles from TPS
1K3868050C 75R - cover
1K0868039B 75R - cover
1K0867179D 75R - Handle
How can you order from TPS as my local one in Exeter seem to ignore my emails
Ring them up :happy2:
There website says they dont sell to the public only trade?
200bhp
Tornado Red
2006
Offline Christiank
  • -Receive: 39
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,110924.0.html
« Reply #10191 on: February 28, 2017, 09:08:26 pm »
http://www.eskoda-shop.cz/GOLF-1K-2004-09?pg=80
http://shop.ahw-shop.de/vw-teile/golf-5-1k
Here go crazy shopping ;)
I did some soundproofing to the roof since I've taken it all out anyway to replace the wire harness that support the dome lights, make-up lights at sunvisors etc..
StP gold on the metal, StP SPL8 8mm and added a layer StP Biplast 10mm as final layer.. Even now when the roof isn't putted back I must what a difference!  :drinking:
Can't wait until some better weather - then the whole floor is up.
« Last Edit: February 28, 2017, 09:15:36 pm by Christiank »
MK5 TDI 2.0 MY2005 - FULL OF RETROFITS:
MK6 dashboard - BCM converted - MK7 cruise control MFSW - PLA 2.0 - 3D instrument cluster - Discover Media 2 - Highline TPMS - 10ch Dynaudio system - KESSY with start button
Offline DBXdarkangel
  • -Given: 18
« Reply #10192 on: February 28, 2017, 09:13:11 pm »
@dools225
Handles from TPS
Dont i know it :(
  • -Receive: 692
« Reply #10193 on: March 01, 2017, 10:19:03 am »
There's always KY or Vaseline for those who like a clean lube.
Aluminium anti seize is the same as copper anti seize, just different metal powder in it.
« Reply #10194 on: March 01, 2017, 11:02:14 am »
Correct... but it is less messy. Ive never liked copper stuff.
  • -Given: 79
« Reply #10195 on: March 01, 2017, 11:19:01 am »
TPS Exeter & Cornwall (VW steakers at Indian Queens - its the place name , honest!) Are Sh1t - Agreed!
I have been unable to get them to deal with me, even as the Ltd company that I still have from contracting days, apparently because its "Marine" not Automotive engineering!
Offline golfmck1980
« Reply #10196 on: March 01, 2017, 09:27:34 pm »
Got the front CAT removed all together today. Really need to get a build thread going for my car
Edition 30 num 859
Offline 6waysforward
  • Boost junkie
« Reply #10197 on: March 02, 2017, 12:05:18 am »
So I was having a good month. Got my highlines fitted along with a kenwood dnx521. Then new Passat window switches and headlight switch. Got the headlight washers working to. Happy Ben all in until..............
Went to get in the car earlier and some complete cod piece has side swiped the o/s of my front bumper  :congrats: no note so it's now down to me to pay for it.
It's gouged it so it's a re paint job. So fast forward to tonight and I take the car out for a run, Come home and walk round the side of the car to see the f*cking headlight washer cap has come off and buggered off somewhere in the 20 mile drive :confused:
2 steps forward, 1 back.
Tornado Red GTI DSG
Offline stacy2704
« Reply #10198 on: March 04, 2017, 09:50:36 am »
the last thing i did was get annoyed :thinking:
Offline PatchySan
  • -Receive: 59
  • Gracie!
« Reply #10199 on: March 04, 2017, 04:35:56 pm »
After 2 weeks of public transport I've finally got my GTI back from the painters and got bumpers and sideskirts colour coded along with my front end getting fixed properly! The only downside is the that it has been p*ssing it down so haven't had the chance to admire the shine on it (plus it's filthy now)  :sad1:
Credit to @shaunnorris7  for the genuine R32 rear and @kam for the R32 xenon lights.
Going to give my wallet a rest now but soon I'm eyeing on a proper cold air feed intake, remap, exhaust and some Porsche brakes!  :drool:
