Author Topic: What did you and your MKV do today?  (Read 4036810 times)
Offline shaunnorris7
  • -Given: 18
  • 2008 GT TDI
« Reply #10515 on: June 14, 2017, 07:39:22 am »
Converted my Mk5 key fob to a Mk7. A bit bigger and heavier, but just looks nicer.
Does this cost a lot? It's a small upgrade but something I'd love to do! Mk5 key just looks so out-dated now.
Morgan, have a look on the customkeys website. They did mine for £40  :drinking:
willni
« Reply #10516 on: June 14, 2017, 03:54:36 pm »
Finished Polishing just need to wax it and source a new R32 front grill badge
Offline Stupots
  • -Given: 18
« Reply #10517 on: June 15, 2017, 07:00:41 am »
@Morgen As Shaun said (and his post is what gave me the idea to try it myself). That's a nice easy option and it's all done for you.
I did mine with £10 parts and half an hour of my time. I little bit of grinding required to get your original key blade into the new mk7 slot (about 1.9mm required and the original is 2.15mm or there abouts). That was the only bit that wasn't straight forward.
The blade is angled 90 degrees different to the original, so takes a bit of getting used to when switching the ignition on. They are also a bit bigger and heavier, but I like the look.
Cheers, Stu.
2006 VW Golf Mk5 Sport TDI 4Motion (140 BKD)
Offline Ryan M
« Reply #10518 on: June 16, 2017, 03:53:41 pm »
Cheers, Stu.
@Stupots Hey man can you give a link to where you bought the parts for the MK7 key, something I want to try out myself before going with the £40 alternative if I screw it up :signLOL:
Offline The Red Warrior
« Reply #10519 on: June 18, 2017, 10:25:04 am »
^+1
I'm keen to know as well and do this.
4ndy
« Reply #10520 on: June 18, 2017, 11:31:40 am »
Offline Christiank
  • -Receive: 39
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,110924.0.html
« Reply #10521 on: June 18, 2017, 09:59:02 pm »
Got some work done this weekend.
Also swapped my key fob to a custom keys mk7 fob, but aint to happy about the fitment? I can't unlock the car and the blade is hitting something on the side... Will have a further look of it tomorrow.
MK5 TDI 2.0 MY2005 - FULL OF RETROFITS:
MK6 dashboard - BCM converted - MK7 cruise control MFSW - PLA 2.0 - 3D instrument cluster - Discover Media 2 - Highline TPMS - 10ch Dynaudio system - KESSY with start button
Offline Stupots
  • -Given: 18
« Reply #10522 on: June 19, 2017, 07:03:07 am »
I have 3 of the Mk7 style fobs left if anyone wants to give it a go. I'll list them in the for sale section for 10 quid each delivered if a few of you want to have a play.
Stu
Offline Stupots
  • -Given: 18
« Reply #10523 on: June 19, 2017, 07:07:11 am »
@Christiank Blimey, how well does the MK6 dash fit? I know it's the same shell, but wondering about wiring loom, lining up with MK5 door trims and things like that. Any gotchas?
Offline Christiank
  • -Receive: 39
« Reply #10524 on: June 19, 2017, 08:09:03 am »
Need to slap over passager airbag, rewire the connection to hazard light switch, need wirering for passenger airbag off light and you have to extend current wires for the sun light sensor in the dash.
I did pull the metal frame of to paint it, that also made it much easier to change out the flap adjustment motors for the clima system.
I'll take some pictures of how the door cords fit later for ya
Offline Octoparrot
  • -Receive: 104
« Reply #10525 on: June 19, 2017, 05:20:20 pm »
My '06 125k GTI just passed it's ninth non-advisory MOT.  :laugh:
Offline Jdizzle
« Reply #10526 on: June 21, 2017, 04:09:02 pm »
I replaced the rear passenger side door lock, which is the 3rd lock mechanism I've replaced... in two weeks! (it turned out only the drivers side rear door was locking all along)
Anyway, as a nice bonus my hazard lights now flash when I lock the car (previously they only did a double-flash on unlock). I guess this means that if your lights don't flash on locking that one of your lock modules is dead.
Offline killarag
« Reply #10527 on: June 21, 2017, 04:54:46 pm »
Just installed my PCV delete plate I got for free from LVS Racing thanks to a deal I bartered with them at Inters
Offline JGTTDI
« Reply #10528 on: June 21, 2017, 05:44:41 pm »
Replaced the V158 potentiometer for the climate control unit. I now have cold air from driverside and passenger side...along with two forearms cut to pieces due to the tiny room I had to work!
4ndy
« Reply #10529 on: June 21, 2017, 06:52:34 pm »
fitted 42 draft  design gear shifter bushes  Tightened gear changes up Feels tight and accurate
