Author Topic: What did you and your MKV do today?  (Read 4006845 times)
Offline tommy2478
  • Instagram Tom_gti5
    • Photobucket Feed
« Reply #6075 on: March 18, 2014, 04:29:45 pm »
Sprayed Wynns EGR Cleaner into the intake system for a little clean, It solved a cold start problem i was having for a few days but now is back not not instantly firing up again. So going in for a terraclean and then seafoamed before full service later in the year..
That shows you have either gummed up exhaust valves or injector issues, possibly gummed up aswell. I would Seafoam or remove the exhaust manifold and have the injectors out. I wouldn't bother with terraclean.. I tried it, wasted money.
Cheers mate, yea been reading your thread on the terraclean... mine has clicked onto 105,000 so im thinking it must be pretty nasty in there, but i still get ok fuel consumption and power is still ok, did feel sharper after i EGR sprayed it i have to say but not sure if was placebo effect  :confused:, How did you spray the Egr cleaner in if you have done it ?? i just followed instructions and removed air filter and put back engine cover and sprayed into the air intake hole till the can was empty ??
07 Mk5 Gti, Rear De-Wiper, Euro Fogs, Heko Wind deflectors, Pro Coils, GFB DV+
Saintsteve
« Reply #6076 on: March 18, 2014, 04:43:11 pm »
I kept the revs to 2000rpm and cracked open the PCV pipe and sprayed in the EGR contents gradually . It does improve it, but gradually starts doing it again. . Inlet off and injectors clean is the way to go IMO.
Offline tommy2478
    • Photobucket Feed
« Reply #6077 on: March 18, 2014, 04:58:31 pm »
Ok fair enough then i will call a few garages around my area and see the cost as dont really fancy pulling it apart myself  :ashamed:, its fine once started its just not instant start on the turn of the key.
Saintsteve
« Reply #6078 on: March 18, 2014, 05:03:10 pm »
Mine was cold starting being very lumpy,which also was causing a very high exhaust Emissions result. (190ppm) failure was 200ppm on MOT. Now injector that was replaced, it's now just 23ppm.  Worth getting an emmisions check done which will give you an idea if the spray pattern on each injector is good..worth doing tommy  :happy2:
Offline tommy2478
    • Photobucket Feed
« Reply #6079 on: March 18, 2014, 05:08:26 pm »
Ok cheers Steve will look into that !! Will it mean an injector is at fault if it was a high emissions result then ?? i have a std exhaust with the center silencer removed .. just in case that raises the emissions results when i get one done.
Saintsteve
« Reply #6080 on: March 18, 2014, 05:21:39 pm »
If you have VCDS, live misfire counter, and watch to see if a particular cylinder is misfiring on idle.  :smiley:
Offline letlifeburn
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,79128
« Reply #6081 on: March 18, 2014, 06:09:06 pm »
i hit this milestone today.
Offline Scooby mic
« Reply #6082 on: March 18, 2014, 07:20:01 pm »
We fell in love a bit
This car origanaly was for my wife but she's let me have the gti for a while and I'm starting to like it nay love it.
The cars a joy to be in at 30 or 70 dependant on the road.
Throtal pedal still feels slightly delayed but maybe a remap will help the feel?
Love how I can tootle about or get slightly serious and blast in and out of corners.
Still pushing the handling (tyres) but I recon a remap and bilsteins with federal rsr tyres and some descent pads will be next
Then a panel filter and exhaust with map
And tart it slightly with wheels and carbon being a red car it'd be rood not to.
Got to say loving it
Offline GTI-Ross
  • Learning All The Time :)
« Reply #6083 on: March 20, 2014, 11:57:16 am »
sat in my car and watched these  2 funny videos:
&index=4
&feature=share
Offline Dave7692
« Reply #6084 on: March 20, 2014, 12:08:13 pm »
Those videos  :signLOL:
Offline andyp
« Reply #6085 on: March 20, 2014, 04:19:24 pm »
Gti has gone off to be repaired after a wall fell onto it on Monday lol
Offline Marc-5-GTI
« Reply #6086 on: March 20, 2014, 04:36:22 pm »
A wall fell on it...... lol.... LOL?!?! :scared: :scared:
How bad? pics??
Offline Dave7692
« Reply #6087 on: March 20, 2014, 04:43:44 pm »
How bad? pics??
Those were my thoughts exactly, I'd be doing my nut if something like that happened
homesqueeze
« Reply #6088 on: March 20, 2014, 05:04:21 pm »
How bad? pics??
  X2!
Offline andyp
« Reply #6089 on: March 20, 2014, 05:16:09 pm »
I've calmed down since it happened, few expletives etc plus wanting to throw things about but accidents happen,  is photobucket or flickr best to use for uploading pics onto here?
