Author Topic: Will GTi Brakes fit onto an early 140 Diesel??  (Read 1994 times)
Offline G-Lader
« on: July 18, 2011, 11:50:35 am »
Morning All,
Noticed in the classified section that someone had advertised complete front and rear brakes off a GTi.
Will these fit onto a 54 plate 140 Gt TDi?
If so, is it a straightforward job or do the parts require modification to fit??
Thanks in advance.
Regards,
Des.
Re: Will GTi Brakes fit onto an early 140 Diesel??
« Reply #1 on: July 18, 2011, 12:32:06 pm »
No they will fit just fine.
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #2 on: July 18, 2011, 02:53:36 pm »
You just need the brackets and the bigger discs (312 x 25 instead 288 x 25 mm).
The Calipers are the same (Ate FN3).
 :wink:
"You get what you pay for."
Offline G-Lader
« Reply #3 on: July 18, 2011, 03:11:10 pm »
Thats great, just the same as the Mk4 Golf then.
What about fitting the GTi rear breaks??
Will the GTi disc's and calipers bolt onto the rear hubs or is there differences??
Thanks again!
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #4 on: July 18, 2011, 04:50:30 pm »
I need to guess, but the rear hubs should be the same on all FWD Mk.V.
You definitely need new calipers that fit the 286 mm rotors.
So the rear mod is much more costly than doing the front. Also improving
rear is not required for spirited driving or even on track. Or do you like
caravaning in the swiss mountains?
Offline G-Lader
« Reply #5 on: July 18, 2011, 08:20:18 pm »
That's all good news, thanks (no towball to attach a Gypsy hut)  :wink:
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #6 on: July 18, 2011, 08:25:43 pm »
all a straight swap dude , done it to mine    :happy2:
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline G-Lader
« Reply #7 on: July 18, 2011, 08:27:45 pm »
Thanks very much gents, it's appreciated!
Offline DamoP
  • -Receive: 115
« Reply #8 on: July 18, 2011, 08:34:42 pm »
if you need any help give me a shout
