Author Topic: coilovers finally fitted!  (Read 5375 times)
Offline patrickcullen87
« on: July 28, 2011, 07:22:02 am »
finally got the coilovers fitted! thinking they may possibly be to low, when i go hard into a corner i get a bit of rubbing :( anyway to cure this without raising the height? heres a few pics...
before.....
after......
Admin Notice Sig Removed - Signature images should be no bigger than 450 pixels wide x 150 pixels high
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: coilovers finally fitted!
« Reply #1 on: July 28, 2011, 07:34:55 am »
Looks good. Rubbing solution may be to add arb's. I used to have the same problem with rubbing mostly at the rear tires, but it went away with just a rear arb.
What brand did you go with?
« Reply #2 on: July 28, 2011, 09:12:25 am »
ARB's are good and help a lot.
Is the rubbing coming from the front or rear?
If it is from the front, have you done the arch screw delete mod?
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #3 on: July 28, 2011, 09:16:58 am »
Yes do Arch screw delete mod, but also what tyres are you running? Any spacers? Shouldn;t rub with standard wheels on... or are they not ed30 wheels?
Looks good though! :happy2:
Diesel Daily Hack.
« Reply #4 on: July 28, 2011, 10:07:08 am »
looking good now :happy2:
Offline big al
« Reply #5 on: July 28, 2011, 10:40:19 am »
Looks fantastic that does mate.
What coilovers did you have fitted?
Is it just the wheels that are rubbing? when I was on coilovers wound down all the way I found that the subframe would catch on full lock before the wheels.
« Reply #6 on: July 28, 2011, 10:42:09 am »
Looks great pal.
Offline Frenzy
  • -Receive: 29
« Reply #7 on: July 28, 2011, 02:03:00 pm »
Looks good but you may wanna block out your reg on those pictures  :laugh:
Offline GarethB
« Reply #8 on: July 28, 2011, 08:07:16 pm »
Stance looks great mate  :happy2:
Offline GazB
« Reply #9 on: July 28, 2011, 08:10:49 pm »
Looks loads better, fitted KWv1's on mine the other week - totally transform the car
« Reply #10 on: July 28, 2011, 09:00:18 pm »
thanks for the comments...not got a clue what brand they are i bought them in the for sale section on this site off another member.
im running standard 225/40/18 tyres.
they are not standard ed30 wheels they are BBS CH rims.
the rubbing is coming from the front when i am turning and hit a bump or turning hard into a corner. i really dont want to raise it up anymore because i like the stance as it is.
i will try looking for the arch screw removal on this and try that  :happy2:
why does everyone blank out the regi on pictures? never quite understood this because people see your reg when u drive past them so is it not quite the same???
« Last Edit: July 28, 2011, 09:02:24 pm by patrickcullen87 »
Offline Frenzy
  • -Receive: 29
« Reply #11 on: July 28, 2011, 09:27:54 pm »
lots more scammers on the internet i guess than out on the streets?  :signLOL:
there's quite a bit of info you can get about someone from their reg plate, best to cover it up to be on the safe side.
« Last Edit: July 28, 2011, 09:29:30 pm by Frenzy »
Offline R444WRR
« Reply #12 on: July 28, 2011, 10:20:02 pm »
Nice fella looks sweet!
I fitted mine today too;
« Reply #13 on: July 29, 2011, 07:18:28 am »
al keep that in mind Frenzy cheers.
R444WRR car looks crackin mate, makes so much of a difference to the look of the car eh?
have you had any rubbing yet?
« Reply #14 on: July 29, 2011, 07:39:25 am »
When i got mine lowered with original r32 alloys on I got a bit of rubbing on full lock but when I changed to the bbs 19"I don't get any,which was a shock as I thought they would be worse
