September 02, 2026, 03:33:17 am
All Things Mk5
Technical Workshop
GT 140 Diesel brake disc sizes
Topic: GT 140 Diesel brake disc sizes (Read 13881 times)
four!
Always Involved
-Given: 0
-Receive: 1
September 05, 2011, 06:18:32 pm »
Hi,
Seems to be lots of choices for disc sizes come up for my 07my gt 140.
I have bought the fronts 288x25
And bought some for the rear 255x10
The rears had a choice of 260x12 but as they are so rusted (and still on the car ) I cant get an accurate measurement.
Can anyone confirm what i've bought is correct? Got a feeling the rears are wrong but parts guy says 255 on the back??
Many thanks
George
Andy
Admin
Just look at my post count
-Given: 39
-Receive: 447
Re: GT 140 Diesel brake disc sizes
Reply #1 on:
September 05, 2011, 07:09:39 pm »
I can measure the ones of mine but It's a 54 plate if that helps
gttdi build thread
r32 build thread
four!
Always Involved
-Given: 0
-Receive: 1
Reply #2 on:
September 05, 2011, 08:07:32 pm »
Yes please
, if they are somewhere handy, it's a right pain to try measuring them on the car though. Not sure if i was measuring 2.5mm of rust build up or the actual size, they are so similar
Do you know if I need to remove the rear caliper carrier? in which case I will need a m14 spline socket?
Andy
Admin
-Given: 39
-Receive: 447
Reply #3 on:
September 05, 2011, 08:11:04 pm »
i will measure them tomorrow as they are at work--you do need to remove the carrier to fit the discs
gttdi build thread
r32 build thread
B3n
Won't Shut up.
-Given: 25
-Receive: 29
Boom!!!!
Reply #4 on:
September 05, 2011, 08:15:07 pm »
Do you have the facelift GT?? The one with the GTI front bumper but with different grills? If so the brakes should be the same as what's on the GTI
If so you should have 312mm front and 286mm rear.
Thats what was on my 58plate
Ben
My Flickr
Instagram: Chappers84
four!
Always Involved
-Given: 0
-Receive: 1
Reply #5 on:
September 05, 2011, 09:12:20 pm »
Its a 56 registered 07 model year. It has the newer type front end but is badged up as GT not GT sport. Looks like I should be prepared for both to be wrong
JPC
-Given: 93
-Receive: 111
Reply #6 on:
September 05, 2011, 09:14:33 pm »
I thought they'd be 312mm
Andy
Admin
-Given: 39
-Receive: 447
Reply #7 on:
September 06, 2011, 04:15:26 pm »
mine where
fronts 288
rears 258
gttdi build thread
r32 build thread
vRS_Pagey
-Given: 66
-Receive: 59
Reply #8 on:
September 06, 2011, 05:10:23 pm »
They will be 255mm, I have just change mine on an '07' PD140, the 260mm size are on the 4-motion. The PD170 has the GTi set up, 312mm front, 288mm rear.
Mine came from -
www.eurocarparts.com
- with my Briskoda forum discount they were under 23 quid per disc, the part number is:
104441258
HTH, Lee.
four!
Always Involved
-Given: 0
-Receive: 1
Reply #9 on:
September 06, 2011, 06:54:14 pm »
Thanks everyone, looks like they should be the ones then
mine also came from euro's, went for the cheapies though 104441251
Got to get myself the m14 spline socket and i'm good to go
Andy
Admin
-Given: 39
-Receive: 447
Reply #10 on:
September 06, 2011, 08:26:05 pm »
my rear carrier bolts were tight so i put a bar on the end of the ratchet for more leavarage and i also put new bolts back in
gttdi build thread
r32 build thread
sandancer
Always Involved
-Given: 1
-Receive: 4
Reply #11 on:
September 12, 2011, 08:14:06 pm »
When you change the rear discs there's ne need to remove the caliper carriers, a little gentle persuasion and twisting should see them drop out. The new ones go in even easier. The front discs are 288mm, the rears 255mm (2004 GT Tdi 140)
Andy
Admin
-Given: 39
-Receive: 447
Reply #12 on:
September 12, 2011, 08:17:17 pm »
must admit i didn't try and get the disc out that way as i was putting R32 brakes on,worth knowing then
gttdi build thread
r32 build thread
All Things Mk5
Technical Workshop
