Author Topic: Lorinser D93 Alloys - do they fit ?  (Read 2056 times)
Offline impuLz
  • PUGPOWAA
« on: October 22, 2011, 03:17:14 pm »
Seen these online and am taken away with how nice they look, but before i get carried away wanted a double check if they would fit a mk5?
offset - 44
width - 8j
diameter - 17"
tyre - 235?? maybe more/less
any help is appreciated. thanks!
Nothing Logical to Enter
Offline sub39h
  • -Given: 189
  • -Receive: 84
PLANS: Stage 2+
Offline impuLz
  • PUGPOWAA
Re: Lorinser D93 Alloys - do they fit ?
« Reply #2 on: October 22, 2011, 04:12:28 pm »
thanks,
Should be able to work something out with this  :happy2:
Offline vRS_Pagey
  • -Receive: 59
« Reply #3 on: October 22, 2011, 04:21:32 pm »
They will fit perfect, sitting 12-13mm further out than OE wheels.  :happy2:
Offline impuLz
  • PUGPOWAA
« Reply #4 on: October 22, 2011, 04:33:10 pm »
cheers i was really starting to struggle, seeing as i only knew the offset&width of the wheels i was looking at and not the steelies sat on the car currently.
 worked out that it would be:    +1mm inside edge  and +13mm outside edge in contrast to an 18" monza
so i am guessing that they would just about fit- depending on tyres?
Offline stevw1
« Reply #5 on: October 23, 2011, 09:09:51 pm »
By my calculations you should have 9mm between rim and arch = PERFICK  :happy2:
Offline dodds-gttdi
  • -Given: 22
  • Edinburgh
« Reply #6 on: October 23, 2011, 09:26:30 pm »
Here's some wheels with the same specs. Fronts only as the rears are 17x9. Think the tyres are 215/40/17 altho I think you really should have 225/45/17 to get the correct rolling radius for a golf.
Another set, this time 17x7 ET 45. Tyres are 225/45/17
